Modifing Ke Frontend Roll Centers
Hi
Has anyone attempted to change the frontend roll centre by installing a spacer between ball joint bracket and the strut ?
Thanks
Andy
You can get some spacers from technotoytuning.com i think
yeah i put the techno toy tuning ones in my ke20 when i lowered it
Pretty sure AJPS make them in a couple of bolt spacings and heights as well. I have them under my AE86 struts.
^T3 are 34mm, AJPS are 40mm (with the option of 50mm for AE86 struts only).
Edited by rian
Looks like something I should be putting then ke20. It's 55mm lower in the front, so how would i work out what size I need?
Jack up the car from the LCA where it bolts to the chassis. Measure how much you have to jack it for the LCA to be back at stock geometry.
Not sure who makes them besides T3 for KE20 so you might just be stuck with whatever they have. Better than nothing, I have the standard T3 ones in my 70 and they work fine.
Edited by B.L.Z.BUB
Maths.
Found this pretty sweet write up about them. Seems that you are not correcting the roll center to stock, but just raising it above a certain point to bring it closer to the cars center of mass.
http://www.meganracing.com/tech/faqs.asp?id=106&subject=Suspension:%20%20What%20are%20Roll%20Center%20Adjusters
I did my best at measuring up my front end.
I either got it wrong or this is the reason my car likes to wander with the camber of the road.
That LCA line is pretty steep Gav-
It looks like I'd expect the rally car to look like. Maybe I'll have a look at this, we've got the ride height sorted and the handling is fine, but its a bit scary drifting in 4th gear he reckons... rolls a lot.
Yeah i mixed up the control arm heights. Heres the ammended version. Also where i estimate it to be with 35mm rca's.
Notice how the "virtual reaction point" moves to the opposite side of the car. I'm guessing its a good thing.
