August 11, 201313 yr comment_664377 Recently installed a 2" tacho in my ke30. This is the one i got from ebay for $30 + $8 postage. "Tachometer 2'' Gauge Wide Sweep 250degree reading 4-6-8 cycl adjustable In Dash" from seller "automotiveblitz". http://www.ebay.com....id=300880814731 Decided to put it where the clock would normally go Made up a simple aluminium plate to hold the tacho in place With tacho bolted in Wired both ground wires and the orange (light) wire to some plugs that would have been used for the clock. Red wire will hook up to plug in photo below, green wire goes to the ignition coil Don't know what this plug is normally used for, but is very handy for the tacho Routing the wire from the dash into the engine bay via this rubber collar was pretty tough, anyone got some tips/tricks for doing this? Blue wire connects to negative terminal of ignition coil (this is the green wire from the instrument cluster) This post is pretty much what I was looking for when contemplating adding the tacho (since my automotive/electrical skills aren't great), so i hope somebody else finds it useful. Report
August 11, 201313 yr comment_664387 Nice job. Looks factory! The rubber collars are usually buggered from years of heat and exposure and you are lucky it didn't tear. Only real option is to push it out from under the dash, but that is just as likely to tear it. Report
August 12, 201313 yr comment_664538 Great job. Did exactly this a loooong time ago. Just need to paint the needles to match the other gauges Report
September 8, 201313 yr comment_666518 Sweet. Nice little write up. I have been looking to get the same small tach for my TE31. Report
October 1, 201313 yr comment_668204 Hey guys just followed this guide and now my fuel and temp gauges aren't working and my charge light stays on. Any ideas? Report
November 15, 201313 yr comment_671862 Routing the wire from the dash into the engine bay via this rubber collar was pretty tough, anyone got some tips/tricks for doing this? The easiest way is to get a stiff straight bit of wire (cut the bottom length of a coathanger) and file the ends so they aren't sharp anymore. Poke it through the grommet between the existing loom, then tape the electrical wire/wires you want to run though to the end of the 'coat hanger' wire and pull it through. Coat hangers are great for anytime you need a straight piece of wire. Wire normally comes in a roll and is a pain to get dead straight. Report
November 16, 201312 yr comment_671923 Tacho looks perfect. Nailed it! Edited November 16, 201312 yr by B-Lugg Report
