So I had this weird knocking coming from my engine, I thought it was the SC12 but I just replaced it and the noise is still there.
I'm 99% sure its coming from under the cam covers. All the timing marks line up and all the clearances seem fine.
It is fine until the engine warms up, only happens at idle. The car seems to drive fine, pulls hard.
Has 264/8.1 HKS cams (not installed by me).
Video of the noise.
http://www.youtube.com/watch?v=P5iEIknu8-c
http://www.youtube.com/watch?v=jMJBT5LI6hQ
First video today, second video when I first got it started after it got warm.
I'm stumped. Cam bearings?
Edited by B.L.Z.BUB
You could remove the camshafts and check all the bits that it rotates on. And also check your valve clearances.
sticky valve failing to close and the piston slamming it up?:S
sounds freaking nasty.
I found this thread : http://www.toymods.org.au/forums/tech-conversions/50521-help-broken-4age-2.html
From his videos it sounds like the same noise, so I'll drop the box and check the flywheel bolts are tight.
All the clearances checked out plus the noise wasnt there when it was in the MR2. Mind you I don't know if it got to operating temperature.
Any other ideas appreciated :y:
The old trick was to stick your ear onto the handle of the biggest screwdriver you owned and press the blade onto different parts of the engine. That helped pin the noise down, it cuts out all the background chatter a motor makes. There is so much noise in the video I don't know which one you're worried about!
Loose flywheels should be pretty rare, and they should stop making a noise if you press the clutch down.
Did it backfired badly before the noise? We had fuel fumes in the crankcase blow up one day and it bent the splash guard inside the tappet cover down onto a cam lobe, making a terrible knocking sound every time that lobe came around. Has a tappet shim jumped out? Can you take the top cambelt cover off and run it with a timing light on to see if the noise synchronieses with a cam in a certain place.
It weill be interesting to see what does cause it.
I did the screwdriver trick but it seems to be coming from everywhere.
Might be rare but it was my first flywheel and I only did them with a socket set, no torque wrench or loctite
fly with loose screws will cut them in no time so if these were loose screws they would be cut by now I think.
Ill pull the starter motor out and see if there is any movement.
