bplymin Posted April 20, 2017 Report Share Posted April 20, 2017 Hey guys, Putting together some plans for a 4age conversion in my KE70 Panel Van. I know it's unusual but I'm interested in putting in an auto trans. My question is if an auto from an AE86 will fit. Would love to hear if anyone has done this before or has some possible options for me. Cheers Quote Link to comment Share on other sites More sharing options...
SloRolla Posted April 20, 2017 Report Share Posted April 20, 2017 It would I'm guessing work? Probably have to cut the tunnel of course. And guessing the wiring would be the same. Quote Link to comment Share on other sites More sharing options...
parrot Posted April 20, 2017 Report Share Posted April 20, 2017 (edited) And likelihood of finding an auto trans? Presumably one from an AE71 would fit? Edited April 20, 2017 by parrot Quote Link to comment Share on other sites More sharing options...
ke70dave Posted April 21, 2017 Report Share Posted April 21, 2017 A working auto of that vintage would have to be quite horendous. I can't see why an ae71 transmission will not bolt on but unsure if you will have issues with the auto "flywheel" as a 4ac is 6 bolt on the crank but 4age is 8 bolt. Quote Link to comment Share on other sites More sharing options...
SloRolla Posted April 21, 2017 Report Share Posted April 21, 2017 If you've ever driven a Toyoglide automatic it turns you off from old autos ;) Quote Link to comment Share on other sites More sharing options...
snot35 Posted April 27, 2017 Report Share Posted April 27, 2017 Surely the torque converter in an AE71 auto wouldn't be tuned for a 4AGE, you may spend all that effort doing it and work out that it drives like arse. I'm not sure if there were auto AE86's, but I'd be looking into that. Quote Link to comment Share on other sites More sharing options...
parrot Posted April 27, 2017 Report Share Posted April 27, 2017 I just had a look. Predictably the torque convertor is a different part number to an Aussie AE71 Interestingly they did have an Auto AE86 in Japan, and it had 4 gears compared to 3 in an ADM AE71. Quote Link to comment Share on other sites More sharing options...
Western Revheads Posted May 1, 2017 Report Share Posted May 1, 2017 yeah if you are looking at putting an auto in, then I guess just get the auto gearbox imported from japan, and/or go to a shop and get them to put a modern gearbox on and get it machined to fit. Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted May 7, 2017 Report Share Posted May 7, 2017 I'm more of a fan of old autos than these guys, I have an 85 Auto celica and if the box is in good order its a nice drive for a daily. Just go for it, nobody telling you not to do it has done it, use the ae71 box. 4age has more grunt than ae71 and would do more with the 3 gears than a 4ac would. U need an 8 bolt flex plate, and that might best be sourced from an ae92 or ae82 if you can find an auto. Might be a bit of messing around to find a couple of nits and a gearbox with low enough miles, but when you do find it it will be cheap as nobody will want the auto gear in general. Quote Link to comment Share on other sites More sharing options...
