September 22, 200620 yr comment_142417 Was out dirt sliding in the KE55 coupe, and the cluch cable decided to give up and snap. -Has anyone replaced one? -Does anyne in Adelaide have a spare one? -How much effort is involved (keeping in mind this car cost $50, but runs like a banshee and would like to keep it as a thrasher.) Cheers Jordan Report
September 22, 200620 yr comment_142418 Go to U-Pull-It and grab a cable. The cable's are a piece of piss to replace so remove the clip holding the cable in under the bonnet and get your arse up under the dash and unhook the cable :D Report
September 22, 200620 yr Author comment_142422 I had a feeling that it would end up being a u-pull-it affair Cheers Jordan P.S: driving from Lobathal down gorge road with no clutch is fun and the gear box does love it :D Edited September 22, 200620 yr by Jordan Report
September 22, 200620 yr comment_142437 P.S: driving from Lobathal down gorge road with no clutch is fun and the gear box does love it :D :D :) :y: is proably what your car is feeling Report
September 22, 200620 yr comment_142539 only having to stop would be fun, but even then you can restart with it in first no worries clutchless gear changing is rather simple in a k50, just gotta match the revs anywho, shouldnt be too bad to fix the only trouble i had (don't know if this is the same on earlier models as mine was a ke70) but getting the bush back thru the bracket on the gearbox end of things can be an ass of a job... i used a little screw driver to gently encourage it through g/l mate :P Report
September 24, 200620 yr comment_142952 lhd ones are a pain in the ass!!! you got 2 pulleys before it comes out on the right side of the firewall Report
September 26, 200620 yr Author comment_143152 yeah I had to stall it and then start it in first. Changing up gears is fine, just changing back while in the twisties was a little interesting. Will be tackeling the problem this weekend Jordan Report
September 26, 200620 yr comment_143209 shouldnt be too bad, just pop her outta gear, blip the throttle to above hte revs you would be doin once in the gear you wanna go down to then hold it against the synchros and theyll slot in its interesting in mine going into second as the synchro is almost fubbared totally :( Report
September 26, 200620 yr comment_143215 lhd ones are a pain in the ass!!!you got 2 pulleys before it comes out on the right side of the firewall ^^ That sucks Report
September 30, 200620 yr comment_143919 Yep, I just replaced the one on my KE15 (had to have a new one made as well, pretty expensive) and spent a while upside down under the dash... but basically it's a simple job! Report
October 3, 200620 yr Author comment_144591 went out to U-Pull-It on the weekend and there were no KE clutch cables, they'd all been pinched or they were auto's Dam it Jordan Report
October 3, 200620 yr comment_144640 I might have a ke30 one if you want it. Just pay postage and you can have it. I'm in NSW Report
