Engine:
7AFE Block and Crank
7afe crank, polished,balanced doweled for the flywheel
7afe standard alloy sump
20v Black Top Head and cams
Supertech valve springs
TRD 0.8mm Head Gasket
Ross Racing 8.0:1 pistons
MRP spec Billet Rods with Aircraft Spec ARP bolts custom made
ARP head and main studs
Electrics:
Autronic SMC
Evo Coil packs
Evo Module
Evo Optical Distributor
Gizzmo Launch controller
Fuel:
SARD 800cc injectors
TRE intank lift pump
Custom Alloy Surge Tank
Aeromotive external pump
Upgraded Braded teflon fuel lines through out whole car
Aeromotive Fuel Pressure Regulator
Big mexh style fuel filters
Driveline:
MRP spec Quarter Master twin plate rally pack clutch
Mrp Spec Custom billet steel flywheel
4agze gear box with a mixture of aw11 s/c and ae92 s/c ratios with some trick mods and a TRD plate lsd
Intake:
20v quad throttle bodies
Custom MRP spec Intake Plenum
2.5" Intercooler piping
Exhaust:
Custom Steam Pipe Twin Port Manifolds
T3/4 Master Power turbo
2x 38mm Tial External Wastegates
3" Downpipe
Full 3" stainless system with a cannon muffler
Cooling:
HDi GT2 spec intercooler
External Oil filter kit with 2x Setrab Oil Cooler
Pushlok Oil lines
Audi A4 alloy radiator 600x300x50
Suspension:
Custom Fortune Auto USA 500 series with Swift Springs
Whiteline front bar
Stock rear bar
Brakes:
Front
Wilwood Superlite calipers
Custom MRP (bazda spec) adapters
Celica GT4 ST205 discs 315x32
Rear:
AE101 rear disc and calipers
Bendix Ultimate pads
Wheels:
16x7" Rota Circuit 10s with Toyo R888 semi slicks for the circuit
Performance:
337.5kw atw on 26psi (detuned to 20psi 300kw with a fatter power band on a smaller turbo for circuit use)
10.88@209357kph 1/4 mile
1.04.8S Pukekohe Park Raceway
1.16.89 Taupo Track 2 (tightened up version)
Custom billet center using the stock OEM harmonic balancer
DUDE! Nice ride you got there mate, looks great. Interesting engine your running :hmm:
How do you go getting that power down through the front wheels?, must be a bloody handful at times.
Thanks for the comments guys.
Defiantly used and abused properly!
I'm about using something different to show up the fancier cars that should be faster than me :).
What does this cost! i've prob spent around $50k on this car now.
I build these engines to sell complete with intake plenum, turbo manifold and turbo etc for around $15k NZD.
Barry
  • 7 months later...
Does the 7afe bottom end bolt straight up to the blacktop head?? Wow might look into this ! Btw awesome work I bet its an animal to drive
