Hey guys I'm asking I have a beams 3sge motor and I'm going to put it in a ke70 does anyone noe what gearbox i was thinking t50 or a supra celica but i don't noe if it will bolt up or if i need an adaptor plate or are there other gearboxes i can use that also will be strong as it will be my drift car
You will only find out when you do it...
The further forward the motor is, the less you will have to worry about the bell-housing fitting. Naturally that will make the handling worse.. I think you will have to cut the tunnel to fit the J160 in there, but not the firewall to fit the motor in.
Cool cause I don't want to spend all my money and go to engineer it to he told no lol
Which is why you should be consulting an engineer before you even buy an engine!!!!!
  • Upvote 1
  • 10 months later...
Hi all,
I know this is an old thread (about a year old) but I was also thinking AND have been researching the beams into ke/ae as I have a n AE71 csx auto, now the question I have is...
Is the auto trans tunnel larger than the manual tunnel in the AE71? if so, would I still have to modify the trans tunnel or the firewall for the J160?
Also what is the distance between the end of the bell housing and the centre of the shifter?
My original plan was turbs 4agze with the jdm manifold, possibly a w58, as I have a mean diff built with big as ford brakes front and rear, so I kind of need an enging to match! haha and thats why the Beams and 6 speed has been going round and round my head because its good power out the box and would be sweet with a turbo hanging off the side too (later on if I so desired).
Any help would be great!
