April 29, 200521 yr comment_41608 mmm, these are nice. a couple on a twin aisan manifold would work well. anyone think they can work out what they are? :D Edited April 29, 200521 yr by Felix Report
April 29, 200521 yr comment_41613 they're obviously some kind of downdraft on a v8 in a hotrod. not knowing much about downdrafts that aren't aisans, i'd guess i have no idea :D they look like they're on a spacer that goes down to a 4bbl manifold tho, wierd edit: they're not carters are they? you'll come out with something like they're aisans :D Edited April 29, 200521 yr by Super Jamie Report
April 29, 200521 yr comment_41623 that's a small block chevy engine, those are rochester carbs, probably what came stock on late '50s early '60s pontiacs that car has some kind of computer control; note the air temp sensor in the rear carb Report
April 30, 200521 yr comment_41659 very nice weber DGV setup :D if not weber, i'd say rochester or possibly carter. very common on all the old school hot rods with flatheads and hemi's. Edited April 30, 200521 yr by CUCUY Report
April 30, 200521 yr comment_41671 KE70 carby's plus 1 can of chrome spraypaint and 3 modified dump pipes of an S13 silvia... am I right??? Report
April 30, 200521 yr Author comment_41698 you are looking at the latest in efi setups from Moon it would have to be the coolest efi setup i've ever seen. makes me want to get hold of a heap of metal epoxy and attack a set of twin aisans. Report
May 1, 200521 yr comment_41730 no f@$kin way :D how expensive would they be. you can buy dcoe throttle bodies for the price of a tuned rebuilt carb Report
September 5, 201016 yr comment_465754 G`day mate, I`m all but certain that they are Stromberg 97 dual throats. They came standard (One only)on Ford Customline 272 Cubic Inch V8`s from 1951 to 1958. Edlebrock made manifolds to suit twin, triple, quad, six and eight. They were a very popular choice back in the days of ford Zephyrs, early falcons etc for a quick power upgrade. They are as scarce as the proverbial these days, but they still turn up on old school hotrods. Cheers. p.s. If you`re keen on home made injection, have a look at the old holden/valiant strombergs. Up to inch and seven eight, single throat and simples as to work on. Report
September 5, 201016 yr Author comment_465763 They are not Stromberg carbs. The are MOONJECTION Stromberg-Style EFI injection bodies from Mooneyes. :lolcry: Report
September 5, 201016 yr comment_465767 Well, it certainly sorts out the usual "how to inject your K motor" questions!! Damm they are nice! Report
September 5, 201016 yr comment_465770 http://www.rodandcustommagazine.com/techar...tion/index.html Report
