Leaderboard
Popular Content
Showing content with the highest reputation on 08/08/17 in all areas
  1. Hi Jake, Appears both your original & replacement alternator are both external regulator types. The terminology is slightly different with terminal markings, from the Bosch to the Chinese replacement one. Somewhere in your engine bay, is the original regulator, which should be best replaced with a new one, to suit the replacement alternator you have purchased. The common problems with these old alternators is that the brushes wear out, and reach the limits of the springs, pressing them against the slip rings. Check out the typical alternator terminal identification listings at this website. http://jasoceania.co.nz/sites/default/files/default_images/alternator Terminal identification guide.pdf D+ on your old alternator is the dash charging warning light. E on the replacement alternator is also the warning light. F or DF is the field winding, which goes to the regulator. B+ is the battery, which is the big terminal on your replacement alternator. Just make sure the new alternator will mount & line up, before committing to buying the regulator. The new matching regulator should have a lead on it that just plugs straight into the 3 terminal socket on the replacement alternator. Let us know how you go. Cheers Banjo
  2. As always I wrote down my username and password years ago, but when I tried to log in today it said the password had to be 6 characters long, and mine is only 5. That finished that, followed up by the Hotmail email I used on it no longer existing according to Microsoft. I think I'll just write it all off as a typical modern day incident as the internet matures. In reality we should be parking truck bombs outside their headquarters.
  3. Early Corollas had alternators with an external voltage regulator, with the regulator box on the engine bay wall. Later Corollas had alternators, with the regulator built into the alternator itself. It sounds like your existing alternator may have an internal regulator, & the replacement one, you've bought has an external regulator. If you can take a picture of the terminal ends of the two alternators, we can probably work out what has happened. The early voltage regulators used a cycling relay, whereas the internal alternator regulators are solid state. Put some pics up, & we'll go from there. Cheers Banjo
  4. Clients who don't clean up their dog shit. My mower isn't a magical shit vacuum.
  5. Hi Mate, welcome to the ol' rollaclub! To be honest the best place to start looking is google. Rollaclub comes up first or second in almost every google result about old corollas. The other thing is to start a build thread:) then you can document your progress for us all to look at, and ask questions about your projects in one place.
  6. Nice car mate. Ref: the dash cracks. If you are in Nsw there is a bloke out Richmond way near Sydney who will refoam and repad the dash with standard style vinyl in a few colours for $450ish. Regards Mac
