Everything posted by Millaz88
Ke70 Gearbox Oil? How Do I Get It In
Hey guys just don't my 5 speed change over and went to fill the box up with nice new oil and can't get the plug out is there a trick or is it just well stuck? Thanks Miller
Huge Carby Problem ( I Think )
Yes thank u even g now it runs like it should lol and doesnt feel like your going up a hill above 4000rpm Cheers man Miller
5 Speed Upgrade
I'm doing mine over the long weekend so I'll let you all know if I get stung or not Fingers crossed it goes smoothly Miller
5 Speed Upgrade
Yeh I drive about 15 mins to work every morning and sit on 100ks 90% of the way so 5th gear would be heaps better for me I very rarely drive through the city or in traffic because of my work hours I avoid most the traffic
Pump jet piston would be rhe one I guess Yeh I think I need a manual so I know what things are called and how they should be Once I get my tax return I'll be upgrading the carby I hope to a quad bike carb from a cbr1000r Hopefully
Ok fixed guys Loomed at the other carb in the shed n worked out it was missing a washer on the large lever thing that sits onto of a spring thing and it was all the way down instead of all the way up so put that in and bang works better now Still needs a tune but it's a million times better thanks guys
Well it just surges most times driving to be honest It does rev past 3000rpm but realy struggles when it gets to about 4000rpm and then pretty much when u back off it just wants to die like it sucks it dry of fuel but I don't know Is the mixture the brass screw with a hole thro it or the steel long one?
All the ac lines seem fine none are cracked or anything It's a vac secondary A mate played with the mixture now it's even worse lol All the rubbers on the carb are perished as and missing
Hey guys just after your opinion On the weekend I thought I would have a look at my carby as it won't open the secondaries and always idles high so I had a look to make sure all the vac lines were on and had a play with the levers and things to see if maybe anything was seized or loose couldn't find anything wrong Now it started running better after I played with the levers and things and idled at a normal rev so I was happy then on my way home from work it started playing up a lil bit then I it's started idleing high again and then all the sudden just dies and other times it just looses acceleration This would be meaning the carbys shagged and needs to be replaced wouldn't it??
Ke55 Owners In Melb
Hi ke55 owners I am giving you the opportunity to get your rear sway bar upgraded to a 19mm one for you and fitted all for the cost of the parts so around the $60-$70 mark Here's the catch it's for one person and must be around melb and be able to come to my house so I can fit it up for you Pm me if you are interested Thanks Miller
2 Questions
Is there any point in making the car run a higher oil pressure??
2 Questions
The reason I want more oil pressure because I have a plan to build the spare engine I have in the shed maybe get the crank balanced and rods balanced for some high revs and fit some zx10 bike carbs and put it into my daily instead of the planed engine swap I had in mind as my budget has dropped by a lot I was planing on running an oil cooler also and tuned exhaust But yeh all just plans and ideas in my head at the moment
2 Questions
What would be excess pressure?
2 Questions
Sorry mate shoulda been more specific it's for a 4kc Thanks for the info tho mate
2 Questions
I'm in werribee mate I have a spare 4k in the shed I will have a play with making it hold more pressure thanks mate
19Mm Rear Sway Bars For $100
Yeh I will be using superpro bushes I'm in tarneit (hoppers crossing) Inbox me for more details if you want mate Cheers Miller
2 Questions
Lol if only I could afford that mate that's my dream but only a dream at the moment
2 Questions
Ok first question How do you guys do the oil pressure upgrade I have read that you put a 2mm washer in the oil pump but where? Ok second thing I have a rattle and squeak over about 70ks coming from my diff only started in the last week seams to be coming from the front of the diff and there is a touch of play in the front bearing is it possible to replace it at home or just look for another diff? I need to get a new diff anyways as it's 4:30 and I want 4:11 but it's annoying on the way to work Thanks guys Miller
5 Speed Upgrade
Oh so the clutch plate might have a diff spline count? Hmmm I'll guess I'll find out tomorrow lol Thanks guys
5 Speed Upgrade
Good cos it's a after work job n need the car the next day and to top it off the engine cranes just sit itself and spewed oil out seals
5 Speed Upgrade
Hey guys just about to upgrade my 4 speed to a 5 speed Now will I have to pull the engine out or can u just slip the box off the back?
Ok e.go.com.au is nearly $20 from my place to Brisbane just as a starter then another $10 for packaging and what not so maybe could get postage down to $30 depending on were u live and what not let me know if you guys think this is unreasonable
That's with austraila post mate I can have a look into e-go.com.au if people want but if I had to take it to a depo it would cost for travel to get there as well as packaging ad what not so it would have to be considerably cheaper to make it worth it for u guys :) Cheers miller
I have worked out postage it will be $35 to send I'm making the new forsale thread over the weekend mate I'll link everyone to it once it's completed
Best Drift Video- Corolla Ke70-Baskerville Raceway
So turns out it is regoed ad they drive it on the road Found the build page for it don't know if anyone is interested but thought I would post it pretty crazy mods done http://www.hardtuned.net/forums/index.php?showtopic=431244&st=0
