Everything posted by Smithius
Ilona The Twincharger Ke55 Coupe
yeah heard of the lowered vn wags shocks, I'm really after something with some adjustment. Sorry to jack your post.
Sorry if I'm asking a stupid question but do you use those kyb's in the rear of the coupe? I'm looking for an upgrade for mine. Cheers Matthew
4k-c Turbo Build!
Is the carby hat aluminum? If so why don't you take it to a fabricator and see if you can get it modified so that it has the correct size inlet opening, shouldn't cost too much and that should stop those annoying issues.
Supercharged, Efi 4K, Ke55 Coupe
Yeah not really a fan of yellow either but I think it suits the car, I'm with you on the black, I'm going to put the pinstripes back on and might get my sparcos powdercoated black as well.
Been a while since my last update, but in that time i have finally got the coupe painted. Had a few little dents and scratches to fill so it took a while to get it nice and straight, also someone had painted the pinstripe onto the front left gaurd so that took a bit of sanding to get rid off. Anyway here are some photos of the progress and hopefully i will have some more phots soon of it reassembled and glossy after it gets a buff on saturday.
Prob not a hot box but where the exhaust manifold bolts up
Yeah the mount for the hot box, yeah its good to have they keys to the place
nah didnt take any, give me your manifold and ill do it for you, only took 5 mins, you could do it with a die grinder or file but milling is nicer even if you can't see it. Its the hole in the lower half of the manifold, nearest to the head and right in the centre, sticks out underneath by 5mm and just fowled the extractors, you could grind the extractors if you want.
Got manifold gasket yesterday so i tried to fit up the manifolds today but the extractors fowled on the inlet manifold where the original exhaust manifold bolts on. A quick trip to work and the offending mounting lug was machined off. So now the extractors and the efi manifold are bolted on.
Finally got the motor and box in the coupe, resprayed the block before I put it in and I also the loom for the megasquirt and the wideband. You can just see them in the corner of the pic where the battery lives. Just waiting on a manifold gasket so I can bolt the manifolds on.
Got a KE55 K50 extension housing and shifter off a member on here, so today i set about combining it with my ke70 5 speed. Fisrt i cleaned and high pressure washed both the gearbox and the extension housing, then i found that 2 off the threads that the shifter bolts on to were rooted so i made a quick trip to work and fitted some helicoils to the stuffed holes. i then painted the gearbox in cast alluminium vht paint and the shifter in matte black vht with a clear coat, looks pretty good in my opinion. Also during the week i got my autometer 2 5/8th inch taco.
Spent the day out in the shed today getting a few of the ittle jobs done that i have wanted to do for a while. First i fitted my new gauges in the original radio position up in the dashboard. I made up a 1.6mm thick stainless steel plate with 3 52mm holes and a 8 4mm holes for mounting. I fitted 3 of the supercheap auto Calibre brand black face led gauges. I have water temp, oil pressure and boost pressure. I also fitted my whiteline 20mm swaybar. I hope it makes a difference, bit hard to try with no motor. I previously painted my rocker cover in crinkle black paint when the motor was n/a and i had the polished su dashpots which was a nice contrast, but it has had some patches of oil on it that is a bugger to remove from the crinkles, so i paint stiriped the cover and repainted it with vht heatproof paint in cast alluminium. Looks pretty good in my opinion. And i chucked the 7K efi manifold on just to see how it all looks together.
Re done the boot floor and fuel tank cover panel in 12mm mdf and covered it in black carpet, going to paint the rest of the boot satin black so that it all matches. Went into work today and made up some spacers for the surge tank and mounted it all to a bit of ally plate along with the bosch 070 fuel pump.
Had my new rims fitted up with new tires today. Rims are Sparco Racing somethings (can find what they are on the net) which came off of an AE86. Got 8mm spacers on the rear to push the track out near to the front. Got some super sticky Bridgestone Potenza Adrenalin RE001 in 185/60 R14, also slightly expensive. Also got my whiteline swaybar in the mail during the week so i might fit it this weekend when i start swaping motors over
Been doin a bit of work to the coupe lately and i now realise that i hate doing body work. Only had a few little dents to fix up but still a pain in the ass. Also i recived a box from VPW with my fuel supply gear. Got myself a 1.5lt ally surge tank, Carter low pressure pre-pump and a bosch 070 (aka VL Turbo) High pressure pump.
Ok so i got the lowering blocks and the front springs installed finally so now the coupe sits nice and low. Really good stance, not too low and with the Monroe GT Gas Rider shocks it rides pretty damn good. Also i scored some Paseo front seats so I'm in the process of fitting them now. Here is the before and after shots....
I had the exhaust done on the coupe today. Just the usual 2 inch all the way through, straight through Lukey muffler, hotdog resinator, and the extractors of the wagz. On anouther note, i got some lowering blocks so i can drop the back a bit but the ones i got for it have the wrong pin diameter. I hate it when you order something out of a catalogue and not one part of it is correct. Pin diameter is 19mm not 25, ubolt size is 10mm not 12mm and the axle tube diameter is 53 mm not 65mm. Anyway thats my rant for the day.
After a bit of searching and looking on these forums every day, i finally found a decent car to house my supercharged 4K. I have had the motor going in my KE38 but running it with 2 different carbys and not really ever getting it to run properly, i recently purchased a 7K efi manifold so that i ca get it running to its full potential. The motor is a KE70 4K that i fully rebuilt with new 40thou pistons, all new bearings, fully reco head with double valve springs, fairly aggresive camshaft that made pretty good power when the car was N/A. I have fitted a SC12 supercharger that is pumping 6psi but that may increase when i get the motor running properly on the efi. To run the motor i have a brand new Megasquirt 2 3.57 and a techedge 2J9 wideband controler and display so i can tune it myself on the road. I have had some help from Brodie on this forum on selecting the parts needed for the conversion to efi. All i really need now is a surge tank and a couple of fuel pumps. The car is an 1980 KE55 coupe in the original yellow colour. Its running on 13x7 Hotwires and as of today its dropped about 40mm thanks to some custom 6kg/mm springs that SLO-30 made for my wagon. Back is going to be dropped with lowering blocks forthe moment but i may get the leaves reset later on. Also has some awsome 80's spec anti tramp bars. Anywho here is some photos of it when i bought it and after i had a bit of rust removed. And swaping the springs over today.
New Project Ke38
To tell you the truth MattyZ, the car at the moment looks like a peice of crap. The paint job is an epic fail. Orange peel with massive craters. The interior isnt anything special. Just a few gauges and a steering wheel. When i get the motor sorted out properly i'll probably get started on the body work. The wheels that looked awsome in the photos now look like crap from sitting in the weather for over a year so i have to redo them again which is a pain in the ass.
New Project Ke38
New Project Ke38
i should say that was the setup until a couple of weeks ago... i couldnt get the SU to work the way i wanted it to so i change it to a 40 dcoe weber so i could tune it better. i will get some photos up soon. the car is booked in to the carby place in a couple of weeks to get a proper tune because it feels like the car is running out of fuel. i can only get it to rev to around 4000rpm before is starts to hate life, so its going on the dyno to be tuned properly
New Project Ke38
After a really long time between updates i thought i should tell you what i have been doing the wags. I got bored of the N/A setup in the car so i decided to have a go at supercharging the beast. Got myself an sc12 from another member on rollaclub and borrowed some supercharger brackets to suit an sc14 on a 4k just ot get some idea of how to mount it up. Well those brackets that i borrowed were shit to say the least, very backyarder spec, didnt line up with the holes very well. Now i should explain that I'm a fitter and turner by trade and i work with stainless steel all day so i have a bit of experince tig welding the stuff. I'm using a v6 commodore idler pulley modified to bolt on the front of the crank pulley with an alluminum spacer, i used this to get the ribbed belt pulley to suit the clutch on the supercharger. here are some photos of the setup so far....
T-H-E P-A-N-E-L
saw this thing in the flesh at the toyoshow today, awsome car so clean, wheels suit it perfectly
Su Carby Issue.....
um, i have the weber, rebuilt it the other day, going in to work tommorow to make up new pipework/plenum to take the dcoe in place of the su. been a bit busy traveling with work so havent had much time to play. ill post up some pics when I'm done
Su Carby Issue.....
snot35, i had the dizzy locked when the car was still naturally aspirated so i could check that it would still function correctly. didnt seem to make all that much difference to the way the car drove, just lost a bit of top end. i picked up a 40 dcoe weber carby the other day so it looks like i'll be modifying my pipe work soon to fit that. the only reason I'm going that wasy is i know that i can tune it, or i can take it somwhere to get tuned. no body wants to touch the su because they say its too hard to get right. i would keep the su if i wasnt having so many issues with the damn thing. i have a pretty good grasp on how to tune webers and i can buy jets for them at the local mechanic so should be easier to get going. thanks to all that help out with some great ideas cheers Matthew
