Everything posted by Smithius
1jz Ke55
Going to be ready for 4,6 and rotor nats later this year
Supercharged, Efi 4K, Ke55 Coupe
The t3 ps arms give you a crazy 1.5 turns lock to lock on the ke55 on the inboard tie rod point, prob going to try them in my bros 35, he has a little more room with the brake/strut combo he got of Ryan
Only thing I could get today was the ra40s, I'm also running the t3 40mm RCA's.
Cheers, its getting there, put the coilovers in over the last couple of days, had a few dramas with the rotors rubbing on the lcas, so I came to the conclusion that you can't use t3 ae86 ps arms with rt132 struts in a 55, you need ra40 steering arms to stop the rub. With the t3 camber tops its possible to get what looks like 4 deg of negative camber which is a bit much, but nice to have the option
Oh and techno toy tuning camber tops, rcas and ae86 ps arms
- Supercharged, Efi 4K, Ke55 Coupe
Finished rebuilding the calipers today, just waiting on new brake lines and the coilovers can go in.- Supercharged, Efi 4K, Ke55 Coupe
Evan, the gland nuts that came with my kyb sw20 shocks are correct for my struts, everyone told me that I needed r31's as well but these are correct, I don't know if the rt132 struts have a different thread to the xt130, but I doubt it, everything else is the same. All you need is a peice of round aluminum 45mm long and it should go together. Mark, the s15 seats aren't that hard to fit if you have access to a decent range of steel, a welder and plenty of time, they mount to the side of the seat on the trans tunnel side of the seat and to the bottom on the other side, none of the holes line up across the seat so you need to pick a datum point and measure from there, I basically have a complete frame welded under the seats made from 6mm stainless steel then the corolla rails bolt to that. If you have a sedan I would recommend s4/5 rx7 seats, the only require one hole drilled in each of the corolla rails, them they bolt in, they sit too high in the coupe for me. I wish I took a photo of the mount I made. .- Supercharged, Efi 4K, Ke55 Coupe
Nah, going to run an aluminum spacers underneath, should be low enough- Evski's Re55 22R Goodness
Ah, sweet.- Supercharged, Efi 4K, Ke55 Coupe
Those camero shocks should be around $250 from the states, just got mine from jegs- Supercharged, Efi 4K, Ke55 Coupe
Cheers, I love the nardi, it had a black leather one in the car when I first got it but the leather is stuffed. Hope to have the front bar, bonnet chrome and windscreen wipers back on today and that will be the exterior done.- Ninjamekaniks Ke55 Hardtop
I've had lukey glass packed mufflers on all my corollas, not straight through though, not enough back pressure. They sound good, but not too loud with that setup.- Supercharged, Efi 4K, Ke55 Coupe
Also got myself a set of rt132 struts to convert to coilovers, ae86ps arms, techno toy tuning camber tops and kyb agx adjustable shocks all round, going to get a set of new leaf springs as well. Fitted some s15 200sx buckets, awesome seats, sit nice, low and back because I'm a tall bastard. Also fitted my nardi woodgrain while I was at it. In the process of refurbing the grill atm- Supercharged, Efi 4K, Ke55 Coupe
Haven't updated this for a long time... After I had a go at painting it in acrylic, and notching it pretty good, I got greenmac80 to re do it in 2pac, and it looks pretty awesome. I also changed my wheels to some southernway epsilon mesh in 14x6.5 +7, had the centers powder coated black and the outers polished.- Trds Rally Car
- Red Rocket's 5k Turbo Efi Ke55s
Does it have solid lifters, if yes then you need to reset your valve clearances- Brodie's Ke30 2Door - Supercharged, Intercooled, Megasquirt, C.o.p
http://www.diyautotune.com/cars/customer/gary_hart_studebaker.htm Have a suss at this..... With the megasquirt you can do boost control, antilag, launch control, nitrous, I'm sure you can do traction control with the correct sensors, you can do everything the top end ecu's can do for a fraction of the cost, you just need the understanding of how to do it, which Brodie has. After seeing and going for a ride in his car, and seeing how well it runs and drives, convinced me to go megasquirt for my project. This thing runs way to good to be a 30+ year old 3k.- Brodie's Ke30 2Door - Supercharged, Intercooled, Megasquirt, C.o.p
Nah haven't done it yet, had a bit of an issue with the paint on the car so that's held me up a bit, still undecided on what to do with the ignition side but I like the look of coil on plug.- Brodie's Ke30 2Door - Supercharged, Intercooled, Megasquirt, C.o.p
Hey Brodie, wanna wire up my megasquirt and tune it for me? Ha ha - Supercharged, Efi 4K, Ke55 Coupe
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
