Mick E
Everything posted by Mick E
  1. most of you might know this, went too bursons in bendigo to get some ball joints. for ke-25 build, thought you might like to know this for future referance ball joints $38 inner tie rods $36 outer tie rods $28 roadsafe items cheers micke
  2. if you have not touched it; it most likely needs anew clutch plate pressure plate and throw out bearing cheers mick e
  3. i think quick release hub on road reg would be illegal, steering wheel lock best option cheers mick e
  4. go onto faqs check under brakes cheers mick e
  5. you need a te-27 pedal box to move booster so mcyl is aganist strut tower, to clear carbys
  6. not illegal to run without a sway bar.does not lca in place cheers mick e
  7. not without a lot of work, i would imagine they would have differant quater panels. why would destroy a good ke-20 body cheers mick
  8. snot35 is that part number a current one. if so where would it be available cheers mick
  9. doogs if my memory is right i fitted vh commodore rear shock, to my ke-25 race car. they were revaled bilstens hope this helps doogs micke
  10. thanks cameron i was checking them out for my 5k race motor mick
  11. av gas is still purple and is leaded
  12. a while back cameron downunder88, had apicture of a k motor.with timing gears are they still available, and where would you get them cheers mick
  13. how or where do you measure ride height on ke 20 25 corollas
  14. according to peter robinson if my memory is correct. bolt ke-70 discs to ke-20 hubs,keep same stud pattern.redrill and tap struts to take ke-70 backing plates should work cheers mick
  15. according to peter robinson if my memory is correct. bolt ke-70 discs to ke-20 hubs,keep same stud pattern.redrill and tap struts to take ke-70 backing plates should work cheers mick
  16. Mick E replied to Mick E's topic in Rollaclub Rides
    keep you informed parrot and others on progress hope too see you at an event cheers
  17. thanks for that parrot; could you post up some web sites and info where to contact them please parrot if possible thanks
  18. Mick E replied to Mick E's topic in Rollaclub Rides
    not sure parrot maybe just stick with ke-25 sprinter theme,will get back to you on the gauges later. will stick with 5k and 5spd bring it back to a std looking 25, will be a slow process cheers fellas
  19. Mick E replied to Mick E's topic in Rollaclub Rides
    very clean and straight very little rust as you can see
  20. is there a toyota corolla magazine available, just like classic ford dealing with escorts and cortinas. if there is, is it available in australia and in english not japanese. thanks
  21. Mick E replied to Mick E's topic in Rollaclub Rides
    picked car up from roadworthy check not much too do. car has 5k 4spd mazda rims ke-70 brakes,pedders suspension body very good needs tidy up. have pics up at the weekend fellas
  22. thanks for your input tally
  23. i meant the ke-25 sprinter thanks cameron
