Mick E
Everything posted by Mick E
  1. i have a ke-25 would like too build it to sprinter specs. ie twin carbs tacho dash what are other specs please
  2. Mick E replied to Mick E's topic in Rollaclub Rides
    sorry i ment to say pics would come later , when i get the car back
  3. Mick E posted a topic in Rollaclub Rides
    hey fella:s just picked a ke-25 , 5k 4spd 13 inch mazda rims ke-70 front brakes. no pics yet getting road worthy, check at the moment in great condition for 74 model corolla
  4. is there a rust repair section for ke-20-25, spare wheel wells. thanks
  5. if its a ke series motor check a manual , you can withone valve downyou adjust four tappets, one full turn you adjust the other four .
  6. 74-ke20 khana cross car alum radiator 5k t-40 gearbox std banjo diff hornet foam filled fuel tank. perspex back and side windows, sparco race seat gutted interior chome-moly cage hyd-handbrake steel bumpers,all other panels std corolla. weight on tested public digital weight bridge was 780 kgs front 420 kgs back 360kgs
  7. great job great price will clean up well
  8. will be up for lcas for ke-20 rack and pinoun for ke-20 you beauty
  9. toyota sprinter carbys and manifold how much did you pay
  10. there,s an adjusting grub screw and locknut on top steering box. adjust in straight ahead position not too much as steering will lock up
  11. evan g they do work, a 16 year old girl ran jb camira. with an elec super charger on it in vcas events went very well
  12. thanks for the replies fellas
  13. thanks trd-ke70 is it possible to get in contact with person that made them, thanks for your help
  14. hi trd-ke70 great job on car. what brand are the extractors on your uprite motor. are they freely available, or are they specially made
  15. 1 exhaust flange 2exhaust to inlet manifold
  16. these are rebel wheels still avalaible in sydney i think
  17. these are rebel wheels still avalaible in sydney i think
  18. 13 x6 superlites 13x5.5 superlites with a 3 mm spacer 13x7 rebels will fit
  19. there is a little bit of mucking about removing the drive shaft cost just a guess about 250 bucks
  20. can only fit adjust camber tops if you have coil overs struts . to get any good camber
  21. most axles snap at spline end should be able to remove diff centre
  22. redwarf is right most axles snap at spline should be able to remove diff centre
  23. if its fwd its most likely a constant velocity joint in the drive shafts
  24. cam the 2 nuts are locknuts 1lh thread 1 rh thread heat adjuster and drop in bucket of water should loosen them
