Everything posted by the_van_can
Ae86 4Age Conversion
if you are on your P's i don't think you will have much luck "legally" driving a converted vehicle, unless you A: Don't mod plate it and watch how fast your insurance company gets out of any claims you make, not to mention CTP if you accidently hit someone, you could literally get suied for millions, or B put a 4age in on carbs instead of EFI, then you can go to the transport office and apply to change the engine number from 4axxx to 4axxx, which I have herd works in some states and not others.
Ke70 4Age 20V
yah i think this was cmerlin, has been sold a few times but an awesome car none the less. actually it suddenly became awesome as soon as it lost the hideous rims it used to have lol, only suggesting is maybe use a cleaner looking rwd cooling system, I think samQ has some rwd 20v cooling parts to make it looks alot nicer. but I'm a bit hypocriticaly my cooling system looks like dogs balls haha.
Phil'S 1Jz Rolla
looks amazing with those windows :y: show us the under car porn.
Yellow Panel Van
cheers mate, fuel system has been changed since then, I have investigated every type of fuel system that would suit this car and it seems I need a custom tank made with an intank pump, because the pano fuel tanks are useless and extremly shallow, but can't afford at the moment, right I converted it back to just the bosche 070 staight from the tank, noisy and surges but I can't do much about it. There are other people with the same car on here that just run the bosche pump aswell. Update: Fixed car, it's running A1 now, also got the injectors cleaned for shits n gigles and the car is now officially scary. must drive with care :P
Yellow Panel Van
yah been a bit slow been pretty bussy latly thanks mate, re-did the fuel system still got a few issues I gotta fix, this might be up for sale in the future, need a more suitable car this thing is soooo much fun to drive, its so hard to get rid of.
Crazy Idea G4Fk Into E7
great for something different, realistically your probably going to be putting in as much effort and money as putting a ca18det in.
7A-4Age Hybrid
my smallport has over 200xxx on it and it dyno'd 112.8hp on open headers with absolutely no mods but the ems computer. i would expect a smallport 7age to make at least 130hp, I guess a good ecu helps.
Bleeding Brakes
haha thanks guys, nah wont need to get a workshop to do it, just wanted to know best way to approach it seeing I have no fluid in the back and fluid in the front, and me understanding how it actaully flows haha. cheers guys
Bleeding Brakes
hi all, this is a pretty basic one, just upgraded the diff in my ke70 and was wondering how the best way to bleed the brakes would be, the brake lines hooked up at the back on the diff but no fluid in them, so should I pump the pedal a tonne of times and try to get fluid into the line on the diff or should I just do the usual routine of pump pedal, loosen , pump pedal, will that eventually get fluid to the back. Also going to change the brake master while I'm bleeding brakes, A mate that doesn't really know ke70's said that there will probably be like 4 or 5 places (other than at wheels) in the brake system that I will have to bleed, sounds a little strange to me? thanks in advance.
Yellow Panel Van
progress, diff mounts are on, old mounts cut off and test fit seems to be good. (the orange tarp was because I was too lazy to clean up diff oil on the floor)
Yellow Panel Van
so the old mounts have been cut off, and the new fabricated mounts have been tacked into place. It was waaayyy easier than I expected. A mate that is experienced doing it helped me out and all we had to do was find the centre point of housing (width wise) and measure from side to side a few things and just tacked it into place, then it's off to get tig welded. If you have the righr cutting disc you can grind off the old mounts like butter.
Herbert The Panel Van
nice find mate.
4age Into Ke70 / Ae71 Conversion - The Step By Step Noob Guide
if it's from AE92 you will need to cut and shut the intake manifold or get a rwd intake manifold with an adapter plate. you will also need to install a spigpot bearing into the crank, the wiring loom will have to be heavily modified as if is for fwd instead of rwd (you could just pay someone to do this if your not confident). You will need to source rwd engine mounts from an ae71 or ae86, then everything else in this engine conversion is straight foward, you will need a pedal box from an ae71/ae86 aswell. it's all writen in the post on the front page.
Yellow Panel Van
sweet, thanks for the info, gathered I'd have to get different u-bolts. just can't wait to get it going again because my temporary car chugs the fuel, spent $63 on fuel in 5 days too and from work, need to get back to the 1.6 litre ftw.
Yellow Panel Van
It's been a while since I've update, Have been having all sorts of engine problems, have a new question in general mechanical section each week to try and fix them as I am still learning alot and my mechanic mates help me with everything. been having pcv issues that just don't make sense and leave mechanics scratching their head but its fixed now motor NEVER blows smoke and always runs great, fixed fuel delivery issues, fuel pumps dieing etc. so anyway engine is always running great when it is running. decided to upgrade the diff to a T series :) also in the near futur I'm ugrading the fuel system so that I can get rid of the surge tank and lift pump and go to a in-tank fuel pump. The fuel smell in the car is too dangerous to inhale, I will also need to weld up the holes I drilled in the rear of the car for the fuel lines. pulled old stocko diff out pic from my phone of the new mounts the new T-18 diff to go in, will require fair bit of modification, the coil spring stuff will have to be cut off new and old diff JDM AE86 tailshaft, hoping it will work not sure. I have 22 spline T-50 going to a t series so it SHOULD be perfect also go my hands on a some AE86 gear for up front, struts, springs, JDM vented and slotted rotors, braided brake lines everyone is going to think I'm mad but I have ultra low pedders springs or brand new king springs at stock 86 height, going to go with the stockies for now, It suits me better to have a higher car, although I want to lower it so much because it would look awesome.
1981 Ke70 Panelvan. Its Brown.
that paint looks sick, great choice. you can't even tell the back panels use to have windows there, that's very impressive. top stuff
T50 G/Box Crossmember Problems
i just did a dodgy and re-drilled the hole, can't even notice the old hole it is hidden beneath the bolt :)
4Age Oil
ok cheers, think i might do another oil change, waste of money that was, never listen to your mates haha.
4Age Oil
it's 5w50. Cheers for the info, will consider something like that 15-40, I've herd that the whole oil leaking from the motor because it's too thin is a load of bs from some people, but i am inclined to agree because oils like mobile one have all sorts of additives like gasket softener and things like that that prevent oil from leaking badly regardless of how thin they are.
4Age Oil
Hi all, seems that I am asking a new question each week in general mechanical. So I have done an oil change on my smallport 4age. The motor is from a wreckers but goes very hard, from what I gather the odometer said on the wrecker car the engine has done anywhere upto 300,000. I have suspicions it has been rebuilt at some stage. Changed to fully symthetic mobil 1, (my mate kept talking it up) so the car runs fine but oil pressure is all over the place on cold start the oil pressure shoots up to 6 bar (87 psi) and with the slightest tap of the accelerator the pressure raises even higher. once the car is warm it stabilises a lot and goes down to around 3.7 bar. But then if I give it a flogging it stays on 3.7 and won't move I don't know whether it's good or bad. And I can't come to a conclusion on the health of the engine because if it can hold 6-7 bar of oil pressure I gather that's not too bad? Should I bother changing oil to something thicker, and some people say once you'v gone full symthetic don't go back to mineral or semi. ( the oil has only been in for 2 days). Any help is much appreciated cheers.
So I Have A Ae71 Panel Van
ok great thanks, so theoretically with modification you can pretty much put any diff in that you like even if had coil springs, providing it's the right length.
wow thanks for that info was going to go get a jdm t series for my pano but didn't realise the obvious there. bloody leaf springs.
Ke70 With Ae86 Front Gear
Thanks for the offer, I also enjoy using your quote :P. I am upgrading my suspension and I'm a bit too materialistic, I MUST have new standard ones lol, was also after ones same height but a little stiff. cheers though, oh an nothing can beat a jacked up camry, sounds like something I'd drive when I was retiring lol no offense beerhead :P
lol good work mate, would of loved to see it first hand it's funny how people with 4wd's think their tuff but have never actually use their vehicles, cheers for the info. sidenote: r.i.p unfortuante queenslanders
Thanks for the offer. That's what I figured so you have confirmed it for me, clearance is win especially in the current flood conditions here. anyone know if you could use ke70 springs on an ae86 strut? I have also been googling that tonnes with no result. Once again I assume that would be pretty much identical to 86?
