morgzz
Regular Member-
140 -
Everything posted by morgzz
do it!!
itll look good in ya window!!! weird old man nextdoor
well done with this car ryan,,, i will reward you with a trophy.. an antique crumpet smashing hammer!!! cheers morgzz
Eiriksmil At The Car Wash, Making It Ready For Winter Storage
morgzz replied to eiriksmil's topic in Automotive Discussion
hahahah i love this -
its a piece of piss dude.. i use a trolly jack under the gear box to take the weight of it when i pull it out... with the clutch cable you have to pull it through the gearbox side.. 1 cur clip on the cable hole and then reach your hand up to the clutch pedal from the inside and pull the cable off the pedal and then your done
make sure you take the spacer plate off from the crack shaft from the auto, otherwise your mannual flywheel will hit the bell housing and wont spin.. i lernt the hard way
leads on the dizzy cap wrong? adjust timing then you should be sweet worked on mine.. all the leads were on the wrong buttons
hahahahahahahah choppies! only have choped springs in the front.. yeh ryan due to not having this car on the road anymore i roach it up in the drive way and the crumpetier rang the cops on me...
i live in a small town and its full of old c**ts that report my car flat out and the cops had enough.. I'm known as "choppies!" at the police station down here.. i wanna find a shell thats registerable and swap everything from my car into the shell
too low too loud no ac pully blows smoke under boost oil leak un supported wires bald tires no horn illigal light bulbs reverse light doesnt work number plates not reflective enough. I GOT REEEMMED
now have a regency defect on it so this car is dead now... might part it out soon if i have enough interest
updaty date!!! :( got to work on the weekend fix the dent and the left fender and rear right quarter and made up a cool exhaust for it!!! so i started sanding and then... welding grinding sanding priming sanding priming sanding primed then paint the exhaust is a cannon with a 3inch pipe welded on the tip :ninja: didnt have time to fix the rust behind the rear bumper but will get there soon ill be putting a stock rear bumper on it... I'm just painting it at the moment.. ill also be painting the centres on the rims gold.... keep posted :)
hahahha ok slanty front looks exactly like a ae71 flat front looks like yours : )
hahahahahahhaha
ohh hahahaha yeh the boss loves it. cheers dude. keep an eye out after the weekend coz ill be fixing that prick of a dent
ok the dent is getting fixed this weekend coming... ive got a straight door and a cut out to weld in the bit under the door... then some sanding and priming and if all goes well mabey some ra40 lcas.... and ive changed my mind about the flat front conversion. the slanty front has grown on me
yes it does dude hahaha... I've got a spare door... but the dent is on the pillar under then door too... so I gotta wait for my dad with the welder to fix it up. pics of magnets?? free plug?
yeh been thinking about it.. might just swap the heads over before this bloke picks it up.. ill just put new gaskets on my car... hows the crumpeteir?
few pics... my starter motor shat itself the other day... good thing I'm with the RAA and got a free tow... the problem with living in such a small town is at the pub that night it was the main topic being talked about... :laff:
bit of an update... started sanding for the new paint job... made a front lip with my mate.. fair epic.. if you guess what it is ill give you a gobby I'm gonna be running my delta streets on the front again and the speeders on the back with stretched as cock tires... I'm going to be cutting the piller under the drivers side door from my wrecking car and welding it in place on mine.. ill also be swaping the drivers side door. then a sand and prime and ready for paint... atm ive got victas pizza express magnets on it because i deliver pizzas at night time in it... FATTEST PIZZA CAR AROUND!!!! pics
hey man nice ride... go the TRX rims.. there not gonna fit on the front without spacers thou man... ill be watching this one
