November 1, 200619 yr comment_149137 I did a search and found nothing to help me so is the 4agze an interference engine ? Edited November 1, 200619 yr by too quick Report
November 1, 200619 yr comment_149139 I am led to believe that a 4AGE is non interference, so a GZE would be as well. Report
November 1, 200619 yr comment_149152 agree with raven on this one non-interference alot of toyota motors are non interference...until you stick an 10.5 mm lift cam in :jamie: Report
November 2, 200619 yr Author comment_149165 So when i change my timing belt and mess it up I'm not going to need to buy new valve and pistons. Also if i put it on and put it a few teeth out can it damage anything else when i go and try to start it ? Report
November 2, 200619 yr comment_149179 I've only ever heard of a modified 4AGE having a problem, Pretty sure stock 4AG(Z)Es should not have a problem.. Report
November 2, 200619 yr comment_149197 nope wont hurt i did a similar thing with my 1g. but it had to do with the oil pump pulley breaking Report
November 2, 200619 yr comment_149198 Was just reading the 4AGE Engine Repair manual, the 4AGE is DEFINITELY non-interference, due to the indentations in the crown of the piston. Since the 4AGZE would be using the same head with different CR pistons, then it too would be non-interference.....in fact, would be even more non-interference (bear in mind this is pure speculation, I haven't actually seen a GZE piston) Report
November 2, 200619 yr comment_149212 On Phil Bradshaw's old website (i have it printed out) the is a reference to cam belts and he expresses that you cannot damage the valves or pistons on any 4age engine, And i myself know that it does not affect the 4A-C. Report
November 2, 200619 yr comment_149257 On Phil Bradshaw's old website (i have it printed out) the is a reference to cam belts and he expresses that you cannot damage the valves or pistons on any 4age engine, And i myself know that it does not affect the 4A-C. On a stock motor yes, Not on a worked motor with different pistons. Following is a link to what I remember Josh Young saying.. http://www.initialdrift.com.au/forums/view...sc&start=45 "in the rush to get it done on saturday, at 9pm sata night josh starts car to test and discovers theres no oil pressure................... the car had run for about 3 mins and then just stopped dead.............. turns out that the LOW oil pressure, (there was some as there was very little damage to any bearings or cam seats ect) caused the exhaust cam to stick, which then, as the engine was running, caused the cam gear to shear off the locating pin into the cam.......... now chain reaction says that the valves are stopped, not normally an issue in a 4age, as they are clearance engines, but this motor has high top pistons and the valves touch the pistons.............. this was only discovered AFTER i had half pulled the engine apart, found the broken pin, the reassembled with a new pin to discover low comp in number 1 cylinder........ " Report
November 2, 200619 yr comment_149260 On a stock motor yes, Not on a worked motor with different pistons. Following is a link to what I remember Josh Young saying.. http://www.initialdrift.com.au/forums/view...sc&start=45 "in the rush to get it done on saturday, at 9pm sata night josh starts car to test and discovers theres no oil pressure................... the car had run for about 3 mins and then just stopped dead.............. turns out that the LOW oil pressure, (there was some as there was very little damage to any bearings or cam seats ect) caused the exhaust cam to stick, which then, as the engine was running, caused the cam gear to shear off the locating pin into the cam.......... now chain reaction says that the valves are stopped, not normally an issue in a 4age, as they are clearance engines, but this motor has high top pistons and the valves touch the pistons.............. this was only discovered AFTER i had half pulled the engine apart, found the broken pin, the reassembled with a new pin to discover low comp in number 1 cylinder........ " The same thing happened to the 4A-C, The oil got low and the cam siezed and i spun the belt so the car stalled driving down the road(AUTO), Not knowing what happened i let the car sit for a minute while i looked over the engine and i turned it over and it started again so i gave it a rev and it died so i hit the key again and only the crank moved (you could tell by the noise the starter made) so i checked the belt and realised it was no longer ribbed. Report
November 2, 200619 yr Author comment_149265 So after reading that do i want to change my belt or get teddy or justen to do it. Report
November 2, 200619 yr comment_149268 do it yourself ya big girl! never gonna learn otherwise are you Report
November 2, 200619 yr Author comment_149269 I just don't want a f@$ked 4agze before i even get to drive it. I will most likly do it and get my mechanic mate or justen or whoever knows what there doing more than me to check it. Report
November 2, 200619 yr comment_149287 Just set the motor to top dead centre (Take the oil cap off and you will see the recess in the top of the intake cam) That lets you know that its on top dead centre. Then make sure the two dots on the cam gears line up with the marks on the backing plate. Check that the crankshaft lines up with the dot on the oil pump body. I marked my old belt with whiteout so I could be sure it went on exactly the same.. Report
