Gearboxes ! ! ! !
olskool
  • Replies 33
this seem to now be sorted but i thought id add my bit, I'm using a early 20 spline t50 with a 4a bellhousing for over a year now with a 20V including racing, no oil leak of destroying the box, I'm using a standard 20V clutch plate that came with the motor and using a standard K tailshaft, Maybe the oil leak problem is the shims for the bearings between the box and bellhousing where not the correct ones etc, I used two on the output shaft and one on the bottom shaft from memory, But as i said it was over a year ago and it isnt leaking there.
