January 16, 200719 yr comment_159809 there are vacuum tank things that you can get for turbo cars to mack sure that there is vacuum in the booster more often. works buy useing one way valves and the like, still uses manifold vac, but holds the vac for when jump on the brakes. Report
January 16, 200719 yr comment_159836 with su do you need to do anything to run boost though them Edited January 17, 200719 yr by c budge Report
January 17, 200719 yr comment_159908 there are vacuum tank things that you can get for turbo cars to mack sure that there is vacuum in the booster more often. works buy useing one way valves and the like, still uses manifold vac, but holds the vac for when jump on the brakes. A servicable brake booster should hold enough vaccuum for up to 5 stops. Report
January 17, 200719 yr comment_159926 A servicable brake booster should hold enough vaccuum for up to 5 stops. I concur!! with su do you need to do anything to run boost though them You CANNOT run boost THROUGH an SU. It just wont work. Report
January 17, 200719 yr comment_159932 You CANNOT run boost THROUGH an SU. It just wont work. Well, it can work. You just have to get the throttle shaft seals installed so it doesnt leak when under pressure. Do some research on the MG Metro Turbo and you will find it is a blow-through SU turbo set-up :) Edited January 17, 200719 yr by Raven Report
January 17, 200719 yr comment_159939 Well, it can work. You just have to get the throttle shaft seals installed so it doesnt leak when under pressure. Do some research on the MG Metro Turbo and you will find it is a blow-through SU turbo set-up :jamie: Hrmm interesting. I think you'd still have a very very hard time getting it to run right. Report
January 17, 200719 yr comment_159940 My plans are for a twin SU supercharged or turbo 4K. Not sure if it'd work well or not though but willing to give it a shot :jamie: Report
January 18, 200719 yr Author comment_160045 with how the tune is on my carby which is really bad the turbo is not very laggy at all . i have a automatic diff in the car and only get about 30kmh out of first gear so the revs rise really quickly and spools the turbo fast and it holds full boost into each gear :jamie: . i chose this turbo even though it was quite large (around a t3 size) mainly because it is sealed correctly, has only done 40,000kms and i got it for 160 bucks so thought couldnt go wrong and id give it a go ;) :y: . it becomes quite expensive when it comes to getting a turbo rebuilt and with the correct seals in it. Report
January 18, 200719 yr Author comment_160050 with the brake booster ill try it on the manifold and see what happens if no good ill run the line to the pipe that runs from the carby to the turbo where theres always vaccum and ill let everyone know what happens Report
January 19, 200719 yr comment_160127 yeah i have/am running a CD 157 strongburg worked really well, and i know of a lot of cars that have been running the CD's and there workin fine, one was even a turbo holden 202 in a LJ Edited January 19, 200719 yr by Hurricane Report
January 21, 200719 yr Author comment_160421 i put my vaccum line for the brakes back onto the manifold and the brakes seem to be working fine. Got a photo of ma car so ill put it on :jamie: Report
