Sign in to follow this
boosted_ke30
Draw Through Turbo Carby Settings
there are vacuum tank things that you can get for turbo cars to mack sure that there is vacuum in the booster more often.
works buy useing one way valves and the like, still uses manifold vac, but holds the vac for when jump on the brakes.
Share this post
Link to post
Share on other sites
A servicable brake booster should hold enough vaccuum for up to 5 stops.
Share this post
Link to post
I concur!!
with su do you need to do anything to run boost though them
You CANNOT run boost THROUGH an SU. It just wont work.
Share this post
Link to post
Well, it can work. You just have to get the throttle shaft seals installed so it doesnt leak when under pressure.
Do some research on the MG Metro Turbo and you will find it is a blow-through SU turbo set-up :)
Edited by Raven
Share this post
Link to post
Do some research on the MG Metro Turbo and you will find it is a blow-through SU turbo set-up :jamie:
Hrmm interesting. I think you'd still have a very very hard time getting it to run right.
Share this post
Link to post
My plans are for a twin SU supercharged or turbo 4K.
Not sure if it'd work well or not though but willing to give it a shot :jamie:
Share this post
Link to post
with how the tune is on my carby which is really bad the turbo is not very laggy at all . i have a automatic diff in the car and only get about 30kmh out of first gear so the revs rise really quickly and spools the turbo fast and it holds full boost into each gear :jamie: . i chose this turbo even though it was quite large (around a t3 size) mainly because it is sealed correctly, has only done 40,000kms and i got it for 160 bucks so thought couldnt go wrong and id give it a go ;) :y: . it becomes quite expensive when it comes to getting a turbo rebuilt and with the correct seals in it.
Share this post
Link to post
with the brake booster ill try it on the manifold and see what happens if no good ill run the line to the pipe that runs from the carby to the turbo where theres always vaccum and ill let everyone know what happens
Share this post
Link to post
yeah i have/am running a CD 157 strongburg worked really well, and i know of a lot of cars that have been running the CD's and there workin fine, one was even a turbo holden 202 in a LJ
Edited by Hurricane
Share this post
Link to post
