Jonny Rochester Posted February 21, 2007 Report Share Posted February 21, 2007 Just put the old Corolla Levin on the dyno for a quick run after work. 80kw at the wheels. I didn't make any changes, just run it as is. 2T-G 3T block - crank - pistons ~305 degree cams, stock cam timing about 110 degrees I recon I could tweek it to 90kw easy if I had the time. Quote Link to comment Share on other sites More sharing options...
flat out Posted February 21, 2007 Report Share Posted February 21, 2007 oh i love seeing and hearing about this car, its pure sexyness, what did the strut brace come off or is it a custom job? casey Quote Link to comment Share on other sites More sharing options...
HEKTIC Posted February 22, 2007 Report Share Posted February 22, 2007 Whos Dyno is that? pretty good effort! and i love this car nice work! Quote Link to comment Share on other sites More sharing options...
st.nick Posted February 22, 2007 Report Share Posted February 22, 2007 Are you ever gonna fix the bodywork Jonny?? Seeing the TE37 all banged up makes Baby Jesus cry... ...and me too almost!! Quote Link to comment Share on other sites More sharing options...
Felix Posted February 22, 2007 Report Share Posted February 22, 2007 If it's pretty, it's not driven hard enough. :lolcry: As my missus says "Pretty cars are for pretty boys". :lolcry: Quote Link to comment Share on other sites More sharing options...
Jonny Rochester Posted February 22, 2007 Author Report Share Posted February 22, 2007 Strut brace is custom, I made it several years ago. I'm working at Jadamzic Auto where the dyno is. When I finnish uni and get some office job in ten years time, I will send the old corolla to some bodyworks and have them respray the whole car. The only TE37 part I don't have is the chrome trim on the bonnet, which I did find in Malaysia via e-mail, but didn't have the money at the time. Other parts I don't need if I keep the KE55 dash. I plan to keep this car forever, will fix eventualy. If the motor ever blows up propper, the next rebuild will be 2 litres and near 200hp. No reason for that yet. I have spent the last 2 years only buying parts for the AE86. Quote Link to comment Share on other sites More sharing options...
tas_ae71 Posted February 23, 2007 Report Share Posted February 23, 2007 crist 80kwatw....????? thats awsome, can we get some more info on this monster?? Quote Link to comment Share on other sites More sharing options...
Jonny Rochester Posted February 23, 2007 Author Report Share Posted February 23, 2007 My car has very simple specs. It would be easy to copy. Basicaly TE37 spec with some sports mods. Here is the info: Engine: 2T-G 88222 head block, crank, pistons are 3T-C. Pistons cut alittle bit to suit 2T-G valves. crank and flywheel balanced 2T flywheel machined on the lathe, down to 6.5kg Reground cams at about 305 degrees (this is the main trick) Irridium spark plugs 2T-GEU distributor and igniter (I use coil and ignitor off Holden Shuttle, as its ND and plugs in) Stock radiator tanks changed to 3 core. Gearbox: T50 from TA22 standardish heavy duty clutch Tailshaft: TA22 item shortened Crossmember: Modifyed to suit 2T as per Toyota manual on my webpage. Carbies: Solex from early 70's 2T-G, with factory 2T-G manifold and linkages Exhaust: 2" Front struts: Corona shortened strut, HiLux 4 spots, vented disks, coilovers, 6.2kg/mm, short stroke. Rear: Complete diff from RA23 Celica, welded for leaf springs. TRD 2-way LSD. Koni shocks. Rear sway bar from late KE55. Front swaybar from late KE55 (its bigger). Quote Link to comment Share on other sites More sharing options...
tas_ae71 Posted February 24, 2007 Report Share Posted February 24, 2007 shit man thats not really that much work for that much power! any idea of the compression..? how much diffrence do you recon the cams made? ive got a 290degree cam with extra lift for my 4ac, I'm not to sure what thats like with the 4ac and i know its diffrent with single cam.. also is that a single down draft solex? how big is the throtte/s do you know? Quote Link to comment Share on other sites More sharing options...
st.nick Posted February 24, 2007 Report Share Posted February 24, 2007 How great would that Levin front end look on a certain KE36 panelvan (ie MINE!!!) :) So Jonny, is she practically as close to a Levin as a non-levin could get?? Quote Link to comment Share on other sites More sharing options...
Jonny Rochester Posted February 24, 2007 Author Report Share Posted February 24, 2007 I feel silly repeating myself on different forums over the years... but thats ok. The idea is to have a complete TE37 Levin, or as much as practicle with a KE55S shell. I often am made to feel silly saying this, because most people in Australia believe the first Levin was a 1998 model AE112 with a 7A-FE. And I am just a little boy putting late model AE112 stickers on my old car!!!! I have a complete Levin badge set for the 1975-77 TE37 Levin, which I got new in the Toyota packets from Japan. (Not on the car untill I have it resprayed and I have a garage.) The only other parts I want is the chrome strip for the bonnet, plus bodywork and a respray. The genuine TE37 Levin had different stiching pattern on the black vinal seats and door trims. The centre console extended further back. There was a foot rest. The early KE30 dash was used with triple gauges (tacho, etc), plus oil pressure gauge and others. (I have a tacho dash I made myself with Celica tacho). The Levin had 13" steel wheels (I have these out the back, same as T-18). The Levin had struts and front brakes similar to Celica (I have coilovers with 4-spots). The Levin had a quicker ratio 16:1 steering box. (I have quick steering with modifyed steering knuckles). And if you don't know what a 2T-G is, look it up... They have sidedraft carbies, solex mikuni brand, 40mm diameter throttles. 4 throttles! Compression works out to be about 10:1 or 10.5:1 not 100% sure. That is with standard 2T-G head, and 3T-C pistons with the pistons cut just a little bit on the exhaust side to clear the valves. 2T-G has bigger valves than 2T/3T. I used 86mm pistons, 1mm oversize. I have used premium 95 fuel. The main rule of thumb with these engines, especialy with 2 valve and not reving past 8300rpm, is that for a 1800cc motor you will not get more than 180hp. For a 2 litre you will not get more than 200hp. With a 4A-GE the head design is better and you can get 200hp from a 1.6 litre (I plan to do this with the AE86). Quote Link to comment Share on other sites More sharing options...
ke20man Posted February 25, 2007 Report Share Posted February 25, 2007 are u ever driving this around the south end of the state anymore jonny? ive seen u at sandy bay makas a few times. Quote Link to comment Share on other sites More sharing options...
Jonny Rochester Posted February 25, 2007 Author Report Share Posted February 25, 2007 Yes I will get rego again in a week or two and give it a wash. But not eating at makas much anymore, trying to loose weight. Quote Link to comment Share on other sites More sharing options...
jamesrolla Posted February 26, 2007 Report Share Posted February 26, 2007 you gunna run her at the collinsvale hillclimb this year??? Quote Link to comment Share on other sites More sharing options...
st.nick Posted February 26, 2007 Report Share Posted February 26, 2007 She sure is a testament to your enthusiasm and dedication to build it all, gathering all the bits from near and far!! When she's all resprayed, badges on and in a shed... she'll definitely be a sight to behold!! Good luck keep us posted!! :) Quote Link to comment Share on other sites More sharing options...
