Calam05 Posted May 29, 2007 Report Share Posted May 29, 2007 (edited) How often do you guys change your gear oil and diff oil, if you change it at all?? My first has just started being troublesome and it bounces bak into neutral, sometimes its harsh sumtimes its soft and i don't notice till i hear my revs and i go nowhere lol. I asked a mate if i should start sussing out another gearbox, but he said first try a oil change. If i was to change the oil how do i do it and how much would i need? its a ke55 also if that helps. Edited May 29, 2007 by Calam05 Quote Link to comment Share on other sites More sharing options...
Clapped out Posted May 29, 2007 Report Share Posted May 29, 2007 Okey doke! by the sounds of things i would get a couple of opinions of why the box is jumping out of gear, I'm not very clued up on the specific workings of them, i just change them if something goes wrong with them lol! and the oil issue it says in the workshop manual to change the diff oil and manual transmission oil every 40,000 kms. Same goes for automatic transmissions as well. I change mine every 20,000kms because i think the oil would break down if it was left in for 40k kms. manual transmission quantity-1.7 litres automatic transmission-4.7 litres, service refill 2.3 litres diff-1 litre hope this helps? Quote Link to comment Share on other sites More sharing options...
Calam05 Posted May 29, 2007 Author Report Share Posted May 29, 2007 thanks for the help, that was the most informative post in here so far lol. How do you change transmission oil for manuals?? Quote Link to comment Share on other sites More sharing options...
Des Posted May 29, 2007 Report Share Posted May 29, 2007 http://www.rollaclub.com/faq/index.php?title=Manual_Gearbox Have a read. Des :sob: Quote Link to comment Share on other sites More sharing options...
coln72 Posted May 29, 2007 Report Share Posted May 29, 2007 Should be a drain plug on the bottom of the box somewhere. To fill, ive just whipped out the shifter and poored it in that hole. can't remember if its the speedo cable hole or another hole in the RHS of the box you fill until the oil comes out of it. Obviously you need to put the speedo/bolt back in :sob: Quote Link to comment Share on other sites More sharing options...
3tg rolla Posted June 8, 2007 Report Share Posted June 8, 2007 How often do you guys change your gear oil and diff oil, if you change it at all?? My first has just started being troublesome and it bounces bak into neutral, sometimes its harsh sumtimes its soft and i don't notice till i hear my revs and i go nowhere lol. I asked a mate if i should start sussing out another gearbox, but he said first try a oil change. If i was to change the oil how do i do it and how much would i need? its a ke55 also if that helps. maybe your detent springs are week and not holding it in gear??? don't think oil has much to do with it! Quote Link to comment Share on other sites More sharing options...
kangaroosa Posted June 8, 2007 Report Share Posted June 8, 2007 Mine used to jump out of 1st and 2nd gear. Turned out to be a bolt had fallen out of the gearbox crossmember, so the the box was leaning over and the shifter would hit the tunnel and knock itself out of gear during heavy launches. The only time i change the gearbox or diff oils is when i break them. Thats about 1 every 7 years so far. Quote Link to comment Share on other sites More sharing options...
Calam05 Posted June 8, 2007 Author Report Share Posted June 8, 2007 i put my new oil in today, i think it actually goes a bit quicker in low gears, but the problem of gears slipping didnt get fixed, it doesnt slip every time now, but my mechanic says probly a tooth broken or sumthing. ill live with it, hill starts are hard cos i gta hold it in first...and my hand brakes falls down as well lol. Quote Link to comment Share on other sites More sharing options...
JiP Posted June 9, 2007 Report Share Posted June 9, 2007 One thing to do then, learn how to do a hill start without a handbrake. :wink: You still after a gearbox?? I might be in the mood to sell one. Quote Link to comment Share on other sites More sharing options...
