hey guys,
i need to do a U-pull-it run and get some tougher springs but i need to get a spring compressor so i can don't have to buy the whole damn strut and waste my money.
anybody know where to pick one up from?
i might try just borrow one but if they are easy to pick up or fairly easy to just make as a shotty, one time use thing it would be much appreciated.
cheers
The rear of EB Falcons are the same coil diameter as KE30/55. The chopped ones that I used to have in my car were 16mm thick wire compared to 12-13mm stock KE30/55 springs. But you will have to chop them in half to get a decent ride height (and then void any insurance yadda yadda). Then there is the stiff as all buggery ride!
Alternatively, you can just get custom springs made up for $140 and keep your car roadworthy.
but yoinking them out falcons, can't u just drop the diff and they will fall out?
or are they the front springs of falcons u put in the rear?
i never looked into it, i just got king springs for 150. made more sense to me
Someone was kind enough to start stripping the rear of the car before i got to it. They were basically loose, so i just tied a random bit of rope to them and gave a big tug from a meter or two away.
Dropping the diff/components would be the cheaper method if he didnt want to buy a spring compressor. Depending how low he is going, he may need a spring compressor to get the springs back into his Corolla anyway.
You actually unbolt the shockers and the swaybar then the diff drops down from memory.
Been a while since I've owned a falcon (considering I grew up with them).
