April 1, 200521 yr comment_37463 direct bolt on from S14 200sx / GTiR GTiR isnt exactly a bolt on job...theres a fair bit of work to it. Try to get one already setup for an S13 :D Report
April 1, 200521 yr comment_37477 no, still has a T25 flange. Both housings have to be clocked (rotated) and you need different oil lines. So its bolt up...but it takes a bit of work to get to that stage. Report
April 1, 200521 yr comment_37487 sounds odd....the main reason people get GTiR turbos is because they have a larger exhaust housing = more top end. Report
April 1, 200521 yr comment_37488 nah same houseing nick o arse. just had to clock both to fit also a gtir t28 is ruffly rated about 320hp. alot more than the 280ish hp rateing of the t28 of s14/15's :D yes and better than the BB spool time is slightly affected , but you don't notice it normal t28's are .64 a/r rears. the gtir is hte larger .86a/r helps tons up top my car hawld arse with a good power band on only 7psi with the gtir t28 anyho. some work does need to go into getting htem to fit * as nick o arse would member * `josh Report
May 19, 200521 yr comment_44865 Why not go CA18DET? I know they fit. My mate has one in his KE70 and one of his mates has 1 in a KE55. :moon: Report
May 19, 200521 yr comment_44867 PeanutBoi78: Out of interest, where did you get your nick from? I'm guessing the "Boi" bit is cause you're a boy (as opposed to a girl), what about the "Peanut" and the "78"? Report
May 20, 200521 yr comment_44870 Ah right. That makes sense then. And why an SR20DET as opposed to a CA18DET? Cause an SR20DET is bigger. Report
May 20, 200521 yr comment_44871 My mate has a Ke70 with a CA18DET,huge front mount and he's running a TO3 Turbo of a VL Commodore on it and is putting out 247.8KW at the rear wheels. But i suppose an SR20DET would be pretty F*%Kn quick in a KE55. :moon: Report
May 20, 200521 yr comment_44878 CA18DET's are stronger!! SR20's are overated, good for big heavy things like S14's or S15's cuz of the torque but for something like yours i wouldn't bother. Report
May 20, 200521 yr comment_44926 Cos i own a 1978 KE55 Rolla (peanut) and yes I'm a boy :moon: actually, ke20 is peanut, ke25/te27 is mango ke55 has no nickname that i know of Report
May 20, 200521 yr comment_44958 I honestly don't know of a good use apart for boat anchorage that suits a CA18DET. I'll bring the blue paint. :moon: Report
