Exhaust Setup For 2t-b On A Ke70
I'm gonna change my exhaust because it's f@$ked..
it seems I'm gonna use the default exhaust manifold.. but what do you guys recommend for size?
first twin 1,5" then 2" the rest?
I want top end power, but I'm also going to use the car as a 'almost-daily-driver'.. so I also want some low end torque.. if ya know..
Edited by David
  • Replies 46
  • Views 13.6k
2" all the way, you could go as large as 2.5" if you're working the motor. mufflers make the exhaust quiet, not the size of it
Low end torque is overrated
Youve obveously never driven a fully laiden truck then....
Torque is good. Going from a 3K to a 2T was amazing. Try and aim for a nice combination. I have a 2.25" system on my celica (2T) and I find it has a nice mid to low torque then she picks up at about 3500rpm.
I also have a 2.25 with extractors on my 2T-geu Straight through muffler under the car and a 2.5 cannon out the back and on the highway its bloody noisy.
not sure what it would be like standard power wise.
I think its gutless over the whole power range, I'm hoping the EFI fixes that, also the twin carbs being a little out of tune wouldnt help.
But I'm also used to my turbo pulsar with microtech ECU and 14psi boost :P
i have a 2" exhaust and it's loud as f@$k. mufflers make an exhaust quiet, not the size of the pipe
on the Camry i have 2" pipe catback no muffler, resonator through to cannon, it is loud enough for my liking, and sound awesome on higher revs.
2" would do you fine from cat back, but 2.25 you could do, but as you get into higher revs you might get this fart/tiny noise that sounds like shit, and you will loose power from it, i would go with the 2" with tuned length custom extractors.
usually the tinny noise you hear with exhausts means the pipe is too big for the engine (3" exhaust on sr20 pulsar ARGH). exhaust tips with a folded over lip can also cause this
everyone knows the best exhaust tip is a 4" black droopy
Love that tinny noise :P
vrrrrrinzzzz vrrrrrinzzzzz hehheheh
actuly more of a vrnnnnnzzz vrnnnnzzz lol
any one herd the 4AGE spirit of trasher.com?
Edited by Jason
it sounds like shit yes 2.5" on a na 2 litre engine full stoko is not good tiny noise after 2000rpm not good.
