What is the problem with it?
I'm currently wiring in a gze and according to the schematic I have the blue\black stripe wire from the Opening curcuit relay goes straight to the fuel pump itself. Surely 4age would have a relay to power the pump itself.
I recently wired up a 4age into an adm sprinter and i had to put a relay on the fuel pump that was triggerd by the circuit opening relay (C-O-R) as the positive side of a pump will allow earth leakage and the charge from the C-O-R isnt strong/constant enough to switch the pump even tho its 12v's.
Thanks for the replies guys. Will be doing more wiring this weekend and will just wire it in the ae82 fashion for now and see if it all functions properly .
