How To: Fix Broken A-pillar Plastics For Ke30-55
This seems to be a common problem as its happened to a couple of my cars, so I thought I'd do a quick 'how to' while I fixed mine as both were broken...
Step 1.
Use a dremmel to grind back whats left of the broken platic seat.
Step 2.
Sit a suitably sized washer over the hole so that its centred and hold it there.
Step 3.
Glue the washer to the plastic from behind. I'm using hot glue, but sickaflex would probably be better.
Step 4.
Use a black permanent marker to hide the washer as some of it can still be seen with the screw in.
Step 5.
Re-fit to car! :hmm:
Excellent stuff si. I did exactly the same to my drivers side one only I sprayed the washer :hmm: I think this has come up before, maybe about two years ago on here meh. good on ya anyways.
hey thats really smart thinking, may I suggest the product Q-bond?
  • 6 months later...
Yeah mate, can pretty much just any clue that won't melt the plastic badly - like some superglue will.
Would probably also recommend NOT using hot-glue as mine has already cracked off again. Just about to re-do them with sikaflex. :P
your a champion mate this has been pissing me off for ages in my 30 i think Q-bond would work well it seems to be able to do anything
Yep Q-bond is what your after, not Sikaflex. Unless its for an area that has to be flexible, cause it sets like concrete
  • 1 year later...
Nice thread man, got this problem but looks like it fixed now.
A good glue option could also be araldite, Use the 5 min araldite and it can have a bit of flex but plenty of grip.
My original hot glue (pictured above) ended up cracking away, I ended up re-doing it with 24 hour areldite and never had a problem since. :wink:
  • 4 weeks later...
Good thinking.
I grabbed some from the wreakers a few weeks back, Cause mine are broken too.
Bugger I should have waited and fixed them.
Cheers
Andy
