Ke-30 2door Rolla
All K50's (5 speeds from K engines) will bolt up without issues. Tho you will want a KE55 5 Speed as the KE70 one would need you to change/cut the shifter position.
thanks man :lolcry:
  • Replies 111
  • Views 25.2k
yeah and if you find a 5 speed i want one :lolcry: mine makes noise =[ =[
Hey guys, its been awhile but iv got the car striped back and iv got (black) primer & (dark blue) paint here acouple pics of the bare metal panels, il be taking the car to a mates house as he has a beter shed than mine :yes: shouldnt be much longer till its on the road :hmm:
http://www.rollaclub.com/board/gallery/122..._102_121407.jpg
http://www.rollaclub.com/board/gallery/122...1_102_34391.jpg
http://www.rollaclub.com/board/gallery/122...1_102_10690.jpg
http://www.rollaclub.com/board/gallery/122...1_102_26978.jpg
thanks,
Ronnie
finally got the hard shit out of the way :yes:
on its way to a nicer garage :hmm:
i'l try to keep the pics coming :P
Ronnie
Good luck on it all mate
PM me if you need any parts, i got a KE30 2 door here :yes:
cheers il keep that in mind, I might need sum parts - probly bumpers, trim.. have you got pics of it on here?
thanks buddy
Hey, nice 30 you have there. :yes:
If it was me, i'd chuck a 4age in. There is heaps of people who are doing it to ke70's.
Hey, nice 30 you have there. :hmm:
yea iv been looking at a 4agze (same thing just stock supercharged) 3k's staying till i get the $$$$ tho :yes:
Went to you pull it 2day and found a weber that'l fit my 3k :yes: A sweet momo Gearnob & i got the little tin rim that goes around the fuel cap
Does anyone have a spare fuelcap with a key in adelaide?
updated my gallery with afew parts but so far havent done alot.. the car should be primed soon, i'l get started tomorow :hmm:
Clean parts
cheers
Ronnie
Edited by r0nn13
done a fair bit of work today cleaning it geting ready to prime it.
heaps of pics :P
Filled in the left rear Q. taped it up from the inside then put the filler on with tape.. worked sick :D
This is the tape on the inside of the boot
puting tape on outside
tape off
after about an hour of sanding back, iv still got to finish it
Masked up ready to start
^I'm going to weld this hole up^
almost up to the easy part :'(
Edited by r0nn13
cheers mate :P
Here sum more pics - Almost finished boging, got the 1st few coats of primer started..
post-7051-1228637990_thumb.jpg post-7051-1228638005_thumb.jpg post-7051-1228638016_thumb.jpg
post-7051-1228638032_thumb.jpg post-7051-1228638058_thumb.jpg post-7051-1228638067_thumb.jpg
post-7051-1228638106_thumb.jpg post-7051-1228638302_thumb.jpg post-7051-1228638117_thumb.jpg
looks sick black :) hope the dark blue works out
Ronnie
Edited by r0nn13
Are you using etch primer on the bare metal? :P
yea doing afew coats & sanding it between.
+heres afew more pics
Edited by r0nn13
