Pcv Valve - Rubber Grommet Removal
Ok, I painted up a rocker cover for my 5k, and I pulled out the rubber grommet for my PCV valve and I destroyed it in the process.
now I need another to go into it, but I can't seem to neatly remove the one from my other rocker cover. Any tips, or is there some alternative solution? New grommet (off the shelf) etc?
Ha had the same problem ,ended up binning it after painting it and makeing it look fast. ;)
I would think the only way would be to try get a new one,as all the old second hand ones old
brittle and rooted by now.
rob
Hmm. too late now. I already busted it out.....
and I've whacked so many coats of paint on the rocker cover there's no way I'll scrap it. I better start investigating something else.....
Might just wrap the PCV in rubber and jamming it in there.
Well could you clamp the hose on to the tappet cover
and put the pvc further up the hose :P
yeah i no dodgee.
Other than that stuffed if i no.
rob
Nope, they're deffinately a grommet. I quickly gave up hope of trying to remove one without destroying it and polished my rocker with it in.
Same here, that thing does not come out! :P
you can buy the gromet stile from toyota and it is cheap to
toyota or a bearing place will get your sorted.
wouldn't a 7k one be the same?, if so Toyota should still make them.
out of a KR42 townace
I'll give them a yell. Wicked.
incidentally, those late model rocker covers are ugly!
I found one of those cool rotor-triangle shaped toyota oil caps the other day at my mates as well!
