Ke70 With T50
does the T50 use the same clutch as the standard K50 gear box i know i need the k-t bellhousing but need to know if i might need anything else
t boxes wont fit k motors and vice versa
Unless you have a K-T bellhousing... and vice versa :cool:
I know there is a K-T bellhousing, never heard of a T-K bellhousing (if you'd be silly enough to use one)
Edited by seabiscuit
do it once, do it properly.
if your so lazy
throw $100 in someones face and I'm sure someone could do it.
Zip ties and 100mph tape FTW
just drill some more holes and she'll be right
i second the zippie ties and 100mph tape
well my understanding is,
belhousing,
clutch setup(hydro) but i think there were some k-t that where cable but don't quote me
modified clutch
modified crossmember
tailshaft should be fine, might need to be shortened?
thats all i think i know, probably way off
you will most probs need a t series clutch, i don't know if the t clutch fits the k series flywheel, but u will need a t series tailshaft they are different to the k series output shaft has more splines
