Oil Oil Oil
...Anyway, if its leaking on the drivers side of the motor it may be worth checking if all of your sparkplug tubes and/or O-rings aren't leaking. I've tried invane befor the fix a "tappet cover oil leak" only to discover it was actually coming from the sparkplugs.
New o rings.
  • Replies 73
  • Views 63.5k
Okay, good and bad news. Yesterday I had enough and I glues the rocker cover seal to the head. That seems to have stopped that leak. But the motor is still wet. The wetness is around the joint between the head and block, the dizzy, oil filter housing and gearbox to block joint.
Now we glued and made a gasket for the oil filter housing to block joint. Stuck a new o ring on the dizzy and stuck a new head gasket in. We didn't touch the fuel pump as the leak isn't from around that plus I had that repaired a while ago.
Am I missing anything??
I still think the head is warped.
The bag to fit the motor in ?
We sell Polyethylene bags at work that'd be big enough to fit the whole motor and gearbox in if you get really disparate
lol
And that, sir, could very well be the problem then
lol
When I took the head to work i put the straight edge on it and even tho i couldnt get a good corner to corner reading due to carbon on the valve recess it still looked slightly off straight, When I put the head on i put wurth silicon special around external area of the lifters/pushrods (general practice with triumph motors and so on) so that the oil side has some 'better' sealing, Unfortunatly after 3 hours or so of fixing a leak Jon just wanted to go home so thats as far as we got.
Check the oil pressure switch, and the spark plug tubes, degrease and try to identify the source.
What has been done:
New fuel pump gaskets.
New oil filter housing to block gasket.
New head gasket.
New Rocker cover gasket.
New spark plug tube o rings/seals.
New dizzy o ring.
Jon will probably have the car back at my house this weekend so i will chalk the block and so on.
Oil pressure switch has been done too. I was looking at the head to block joint tonight and could see a space where I can't see the glue, it looks like a hole. Not sure if it means anything.
Edited by JiP
umm as per our convo after the dinner man have you changed your oil yet?
member what i told you about my old engine and how it stopped leaking after i changed oils...
remember to do filter too.
Yeah i changed the oil i use now. Its HPR-30.
How much oil is being used per week?
So the head wasn't machined when the HG was done!? :lolcry:
Did you happen to also put a straight edge over the top of it trev? Ie check the tappet cover sealing area is also flat?
How loose is the dip-stick? Have also seen blow-by through the dip-stick shaft that leaks in that area. Easily fixed with some leccy tape on the rubber stopper at the end.
