May 30, 200917 yr comment_348558 HI PEOPLE ANYONE KNOW HOW TO FIT A 7K INTO A KE20. I WILL LIKE 2 KNOW WHAT I HAVE TO DO TO PUT IT IN. WANT I WILL NEED TO MAKE IT WORK :rolla: ANYONE NO WHAT BRAKES WILL FIT ON THE FRONT. ANYONE KNOW IF THE VL DISC DIFF FIT ONTO KE20 IF SOMEONE KNOW ANYTHING CAN U PLEASE HELP ME :hmm: CHEERSS :D :D Edited June 3, 200917 yr by LZYBOY Report
May 30, 200917 yr comment_348562 Wow... I don't usually lock newbies threads but this ones so shitty I'm going to. I suppose your username is rather apt. Please, speak English, none of this SMS bullshit and do some research first. Report
June 1, 200917 yr comment_349048 He emailed me asking to open it again, so I did on the proviso he edit his post. He has and while its still not real fantastic it's better than what it was. Report
June 2, 200917 yr comment_349239 Fairo. I'll point him in the right direction then. :bash: here is your answer Report
June 2, 200917 yr comment_349242 Taz for some reason your link got screwed with. :bash: Here is the link Taz was trying to link to :y: Edited June 2, 200917 yr by Felix Report
June 2, 200917 yr comment_349443 This guy needs a does alright..... Edited June 2, 200917 yr by philbey Report
June 2, 200917 yr comment_349479 This guy needs a does alright..... With a 7k in he should be able to does it up well :bash: Report
August 14, 200917 yr comment_365915 There's no 1 word/sentence answer on "The Answer To Put A 7k Into a KE20!" It takes work, figuring things out for yourself etc. The things that need to be done are (from what I've read) the sump needs to be modified (how you'll need to figure out for yourself as it has to sit over your crossmember). If you're keeping the standard K gearbox, you'll want to fit a 3/4/5k flywheel and clutch to it so it can fit inside the bellhousing of your gearbox. I think you'll need to do something with the engine mounts too! Someone else might know what to do with that.... BUT the best way to get an answer is research it yourself, use the search button up top "7k KE20" or "7k" by itself may give you a wider field. Get to work :) EDIT: If you haven't already got a 7k motor, I'd suggest putting a 5k in. MUCH easier! Edited August 14, 200917 yr by seabiscuit Report
August 14, 200917 yr comment_365964 The 7K ute motor puts out 60KW. You would be better with a 3A or 4A engine, from 67KW in a 3A up to 120+ for the 4A-GE. Still, if you really want a boat anchor... Report
