July 26, 200917 yr comment_361506 hi all, I'm doing a 4age into ke70 conversion and have come across one of many problems, the rubber on the motor side of my injectors don't fit snuggly into the holes, they slip in and out with no effort. my question is, is this how they are supposed to be or do i need to invest in a new set of rubber rings? my thoughts are that when the fuel rail pressurizes the injectors gets pushed into the hole and they seal from the amount of force placed on them from the fuel rail. any help appreciated cheers Report
July 26, 200917 yr comment_361533 Got the rest of your fuel system setup and working? If so bolt the fuel rail on, power the pumps and check for leaks. They do sound a bit too loose though. For $5 worth of O-rings I would probably just replace them though. :) Report
July 27, 200917 yr comment_361748 The things you see in the above picture should secure the injectors between the head and rail tightly. Mine just turn/twist, they don't move up and down or anything like that. Edit: You should also have some 'spacer' things in between your rail. Edited July 27, 200917 yr by adam-__- Report
July 28, 200917 yr comment_361960 Replace them all. All three of them per injector. They are cheap and readily available from fuel injection places. Pressurized fuel is not something you want spraying around your hot engine bay. Report
July 30, 200917 yr Author comment_362565 cheers for that, yeh i have already replaced the o-ring that goes in the fuel rail with super high pressure ones that are made for hydraulic lifts so it can withstand plenty. ive got wierd big o-rings on my injectors, they sorta look like a square donut. about 4mm tall 3mm wide and was thinking that they might cost more than 5 bux Report
July 30, 200917 yr comment_362569 cheers for that, yeh i have already replaced the o-ring that goes in the fuel rail with super high pressure ones that are made for hydraulic lifts so it can withstand plenty.ive got wierd big o-rings on my injectors, they sorta look like a square donut. about 4mm tall 3mm wide and was thinking that they might cost more than 5 bux they aren't actually that shape before they installed, they go that shape after installation Report
July 30, 200917 yr comment_362573 If you look at Adam's photo above, the top O ring is the critical sealing ring, BUT if the two insulators aren't sitting right, the injector will be too loose allowing the injector to move about and possibly not seat correctly - thats bad. You can't see the bottom insulator in the photo very well, but the ones there are screwed. Worthwhile checking you have the correct fuel rail spacers also. Report
August 1, 200917 yr Author comment_362858 the motor was running perfect before i rebuilt it apart from the smoke caused by the warped head so are they round when they start off? i think ill go to toyota and buy some new ones cheers for all the help people Report
August 1, 200917 yr comment_362912 orings should always be used once.. quite often thy will do the job more than once.. but just as often, they don't. the upper and lowers are round.. but I'm pretty sure theres a 'square' oring in there somewhere too? anyways, lightly lube all the orings with grease/oil before installing, and NEVER force them in. if they don't slip in with a bit of resistance, theres something going on. Report
August 2, 200917 yr comment_362935 also remember that the injectors being "loose" in the head will also create vacuum leaks = bad. when i put my 4age together, i got my injectors cleaned, some dude came around in a van, put them on his machine for 15mins,gave me a print out on the flow test, and put new rubbers on all of them, was like $120! bargain! Report
