Where To Buy Radiator Hose?
My bottom radiator hose is cracked on my ke20, i went down to my local parts shop and they said they are not made anymore for my car. Surely these can be brought from somewhere? Or is there another thats a close fit?
hey man take the old hose off and take it to your local auto 1 or somewhere like that. thats where i get all mine from
and if the fails then you can goto malz, they have every radiator hose i could think of, or if you need it asap get some pipe and some pipe bender (looks like a spring with a bar ot metal on the side) and make your own :)
ke30-55 should be a good match even a ke70 hose would fit if you trimmed it.
Come and see me at work tomorrow morning Troy. I'll PM you my work number.
We'll see if we can get a close enough match and I'll do you a good price :)
Yay ill be round about 11:30?
Thanks!
Yea it is starting to get hard to find consumables for the old girls.
Not sure on the ke20's, but with my ke15 I used a ke30 bottom hose. I cut and shut it using a bit of metal pipe in the middle with a couple of extra hose clamps. The upper ke30 hoses also work great with a bit of trimming.
Yeah go an see Raven. Been to his work place a couple of times and they have always come through with either the right part or a suitable replacement. :)
Whilst doing an engine conversion i stumbled across these.
VULCOFLEX
They come in varying lengths and Internal Diameters. Generally about $15 each and can be bent into any shape that the original hose was shaped to.
I got mine from an industrial hose and pipe shop (they are a GATES brand), however i know for a fact that you can order them from most auto parts shops aswell.
