Interchangeable Parts
Hello everyone. I just had a bit of an idea. Could everyone pitch in to help make a list of interchangeable parts between each model of corollas. A lot of people ask will a kexx object fit on another kexx model? So what if we made a permanent pinned list of parts that have been proven to fit within each corolla series sub forum that is continously updated. Tell me what you think, thanks
Here's a start.
- KE1x, KE2x, KE3x manual gearboxes are the same. Only difference is shifter angle/lengths, which
can be swapped with correct one.
- A KE70 manual gearbox WILL bolt into all K series Corolla's, but will require changing the extension
housing to an earlier model item as the shifter positions are different.
- K, 3K, 4K, 5K engines, which come in all KE Corolla's (depending on the generation of each car),
apart from the 5K, which is from KM36 LiteAce vans, forklifts, and some Japanese KE7x Corolla's,
all bolt into each others engine bay. NOTE: KE70's have different engine mounts. Some ancillaries
are interchangeable between engines such as carburettors and distributors... SOME.
- KE30 axles (Borg Warner) will fit in a KE20 with a small amount of shortening to convert
to 4x114.3 stud pattern.
All KE30 and KE55 (including KE35 and KE55 coupes) items are interchangeable between each other
AS FAR AS I KNOW. Obviously certain coupe items cannot be used on a sedan and vice versa.
AE86 Sprinter struts bolt into a KE70.
*sigh* Falcon springs... I won't say any more.
TE72 (T-18) struts, diff and a few other things which I am unsure of bolt into KE70.
Can't think of any more right now, but that's a fair lump of it I assume.
Edited by seabiscuit
This thread will only work, if people ONLY STATE WHAT THEY KNOW FOR CERTAIN VIA PERSONAL EXPERIENCE.
No, "I heard this", "a mate reckons", etc.
And no-one asks questions in the thread other than to clarify a specific point.
I am keen for a thread like this, though my interchangeable experience lies mainly in AE86's so shall say little and watch with interest.
Well Parrot maybe you can start a thread in the AExx forum, Yeh it would be good if people only list the things that they have 1st hand experience using. Thankyou
Anyone here know anything about AE82's :wink:
AE70 and I were actually going to do this 3 years ago with the cars, Kinda like a gregory's manual but we were always too busy and never got around to it.
Shortly I am going to be doing an AE82 single cam to twincam conversion guide/walkthrough but that is when I pick up the car.
- 4age RWD, If you have the RWD waterpump and alternator setup and aren't bothered running the heater or throttle body cooling then an easy way around this is to use the rwd 4ac bypass pipe and an AE82 4age rear water housing and use a 90 degree hose between the 2.
- AW11 mr2 - The internal airbox resistor that always fails is also the same as an AE82.
- Celica & MR2 Springs, ST162 through to ST205 rear springs are the same as AW11 rear springs.
If we are going to do a categories then I will add more in there.
Sorry Trev but this is in the kexx section so if you want to start a thread about the AE82 maybe try starting one in the AEXX sub forum, thanks
Don't have to swap extension housing if the ke3x/5x is an auto (they have the hole back a bit in the right spot for the ke70 box).
BUT, only the early ke30 has the 2 mounting points for the transmissions. Late '30 and '55 has only the mounting points for the original transmission used in the car.
Or you can just cut the hole as needed.
TE72 (T-18) struts <snipe> bolt into KE70.
Urm, yes and no. Yes they do bolt in but no they will not bolt onto the ke70 steering arms along with the top hat bolting onto the body of the car. You'll need the steering arms from the donor car and use the top hat from the ke70.
Its the same for the ke3x/5x.
And if you've only picked up the struts from, say, the t-18 and forgot the steering arms you can use t-18, ae86, corona to name a few.
They also share the same shock absorber
And yes :wink: i agree with parrot - No hearsay stuff, fact. And if something interchangeable had to be modded to fit, please add what had to be done saves confusion etc
I say pin it and let the interchanging begin.....
Edit - woops :(
Edited by towe001
Here's a start.
Not quite correct. Ke10 boxes have a shifter further forward than the 20's. There are 3 locations of shifters, ke10, ke20/30/55 and KE70. There are also different output shaft splines but I don't recall the specifics.
Not necessarily, just cut a hole.
- there are also different engine mounts between earlier models, KE10's differ from KE30's for example
- 5K's have bell housing braces that clash with the steering drag link on earlier cars, particularly in KE10's.
this is a difficult task and immediately we've hit a snag with our information. The only way to make this useful it to produce a chart, with the Car models on the X axis and the individual model parts on the Y axis.
Otherwise this thread will become a nightmare of disinformation and arguments.
No I'm not making a chart....... Not right now anyway.
Edited by philbey
There are also differences between early ke20ish and later gearboxes. One bolthole on the drivers side is half a hole out.
Both Jap and Borgy KE30 axels can be used to do this as long as the KE20 diff matches. ie Jap to Jap, Borgy to Borgy
Yes well I can't delete posts or edit them or anything but like I said I only wanted information that you can back up with first hand experience none of this "one thing is the same so it SHOULD work" I wanted info that has been proven to work.
Fact only post.
6/77 hardtop has both bolt holes for transmissions.
not fact. Suspect that when the trimatic came toyota had to stamp 2 different floor plans hence only the bolt holes required. in the similar vein 2 mk II escorts. Autos had a bigger tunnel.
As pointed out a graph is needed in this thread...does it fit? what car? etc!
