June 22, 201016 yr comment_446699 Hey all just wondering what power outputs have people had going through a T50 and open wheeler T series diff before they ran into issues? or roughly what the limits would be. Report
June 23, 201016 yr comment_446735 ....and how knackered or fresh the stuff is to start with. Mate of mine just blew 2nd gear out of a 22 spline. Took 20+psi in a 20v hybrid motor mind you. Report
June 23, 201016 yr comment_446778 T50 is only 'supposed' to withstand 200hp but depends on the weight of car and how it is treated, you can brace the box together to stop it blowing apart. Report
June 23, 201016 yr Author comment_446793 Diff and T50 are in my TA22, will be used as a daily and for a few spirited drives, lookin at a 3SGE with a bit of work done to it, any ideas for box upgrades then, W58? Report
June 23, 201016 yr comment_446804 Diff and T50 are in my TA22, will be used as a daily and for a few spirited drives, lookin at a 3SGE with a bit of work done to it, any ideas for box upgrades then, W58? Different box again, Dunno what the strength differences are but the early T50 is a 20 spline, Grab the box out of an ST corona. Report
June 23, 201016 yr Author comment_446829 Different box again, Dunno what the strength differences are but the early T50 is a 20 spline, Grab the box out of an ST corona. cheers for the advice/help try w55 after t50 if it breaks cheers for the advice/help Report
June 23, 201016 yr comment_446833 try w55 after t50 if it breaks Hell to the no! score a J160... I've seen them around for the $300 mark, which is pretty cheap considering. It'll bolt up to your 3SGE and fits the same spline as the W55. I've heard rumour they are even the same length. 6 speed FTW! Report
June 23, 201016 yr Author comment_446849 Hell to the no! score a J160... I've seen them around for the $300 mark, which is pretty cheap considering. It'll bolt up to your 3SGE and fits the same spline as the W55. I've heard rumour they are even the same length. 6 speed FTW! Is the J160 Or W55 around the same lenght as the T50? Report
June 23, 201016 yr comment_446852 open tseries diff. 150kw atw drag racing. snapped an axel and wrecked the inside of the pumpkin. Report
