October 26, 201016 yr comment_478203 ok here's the thing can i put power steering in my 3k ke30? if so how much power will i loose Report
October 26, 201016 yr comment_478205 one must ask why you want it? put more* air in your tyres if you want lighter steering!:P *taz is correct, one thing you don't want is my air in you tyres. that wont end well. Edited October 26, 201016 yr by ke70dave Report
October 26, 201016 yr comment_478206 one must ask why you want it? +1 why? Corollas have light as steering. BTW I think Dave means "More air" no "my air" :wink: Report
October 27, 201016 yr comment_478560 I got a better solution teach your girlfriend to rotate the steering wheel only while rolling forward or back, even very slowly like when parking :y: Report
October 27, 201016 yr comment_478564 Hit up your local pedders buddy they're sure to tell you if i can be done or not. Report
October 27, 201016 yr comment_478565 You can get places to install electronic power steering...not needed unless you run wide wheels or slicks...otherwise grow some guns. Report
October 27, 201016 yr comment_478597 I'm running 6.5 inch wide wheels at the front, and to be honest the wheel was harder to turn with the original pizza cutter wheels Report
November 1, 201016 yr comment_479625 313i bmw bolts straight in just need to custom mount for the pump Report
November 2, 201016 yr comment_479726 313i bmw bolts straight in just need to custom mount for the pump got any pics or links or anything? cos this sounds a little crazy to me Report
November 3, 201016 yr comment_479909 313i bmw bolts straight in just need to custom mount for the pump got any pics or links or anything? cos this sounds a little crazy to me Sounds a little crazy to me too, I'm guessing this is a BMW power steering rack somehow bolting "straight in" to a car with a steering box....? Report
November 3, 201016 yr comment_480084 agreed how does this 'bolt straight in'?? The ke30's don't have a steering rack and would ba an absolute mission to get power steering working unless you have a brain a mechanics degree and a welder Report
November 4, 201016 yr comment_480150 For it to bolt straight in, youd need to bolt in the whole coloumn aswell + linkages...... Maybe he means it like yeah man 13BT bolt straight into mazdas! Report
