spencer its looking good it pretty excitting :D becuse its coming close to a finish
19914afc i had a mind blank door jams could you explain :S
And it will probs be out by the end of the thuoght night
So i did some calculations i should beablee to afford tires for the ma61s and they will be black with a silver lip should look good
Then on to the next chaptrt wich will be zenki lsd coilovers in the front in the next month and a half
Door jams, the painted body work you see when you open the doors that isnt visble from the outside.
Looking good man, I'm pretty motivated to do mine very soon..
Because my car was white and I painted it white I really didnt mind doing mine a close door but if you going a different colour I would suggest and open door
its all good cuz its white
man all I'm thinking about is that my rolla will be done soon girlfreind say i love it more then her
and that when she is naked in front of me ill still think about corollas
:lolcry:
so i may be getting the tyres done in a thoughtnight rims done paint done
the type of white will be pearl white with a black front end (the bonnet area and the suruondings like toranas appraently)
then the fun begins i guess i might just ditch the freakin afm tacho and steering wheel :)
so it wont be long now :) and i will have it back :) :)
Edited by t18drifts
UPDATE: ok so today we only got time to paint all the trim door handles key holes n shit
oh and the rims are all black and shiny :rolls: scratched the silver lip idea :) looks good though just black :)
any sugestions on a tyre size with a nice stretch
What's the point of running dangerously skinny tyres just for the "stretched look" when the rims you've got are narrow enough that a normal size tyre will fit under the guards anyway?
In my case i need stretched tires to get the wheels under the guards at the front so i can turn without ripping my flares off
The rears have minimal stretch.
But they're not dangerous? I've run 185's on 8" rims for 18 months with no problems at all? They seal fine and hold the bead properly.
And they were fitted by a tire store so can't be too bad..
That said there are exceptions. Like 195/50 on a 10" rim
Edited by Jono.C
Dangerous as in not enough grip. 155 might be fine for grandmas tiny shopping trolley car, but if like most kids, you plan on driving this thing fairly hard, put some decent tyres on it. They're pretty much the only safety feature your t18 will have. On the road I use a 195 RE001 on a 7.5" wheel. Has a slight stretch and is good for moderately hard driving. I use softer 205s though when I need to push the car a bit harder.
ok guys ill just go and get some normal non stretched ones then :)
i just thought about it then the rims are inside the guards well and truely so no need for stretch :blush:
but don't they look good in black :)
