March 30, 201115 yr Author comment_513735 I personally wouldn't waist my time with wiring the 7k ecu, they won't recognize boost therefore running lean under boost. One question I have is are you going to turn the blower off once you've reached desired boost pressure from the turbo? I'll probably have a choice of two heads for you mate cause I've got a spare head in the shop at the moment. So I'll also have the one off the car aswell. Stu. I wasn't planning on bothering with the 7K ECU, I was talking about working out the wiring. UNLESS you don't need it all when you run an aftermarket ECU. I wouldn't know lol. As for the blower, I don't plan on turning it off. It has an aftermarket pulley on it(12PSI) and is no longer clutch controlled. I was thinking this would make it painful to tune though. I'll deal with it when it comes to it, I guess. Cheers, Jake. Report
March 30, 201115 yr comment_513768 hmm i don't like the way u guys worked out ur setups id run turbo into charger with a waistgate inbetween then intercooler then carby with a bov somewhere between charger and motor. the waistgate acts as a bypass for the turbo once u reach a certain boost from the setup so the charger wont choke the system. thats how I'm goin to setup mine but I'm running efi Report
March 31, 201115 yr comment_513820 I wasn't planning on bothering with the 7K ECU, I was talking about working out the wiring. UNLESS you don't need it all when you run an aftermarket ECU. I wouldn't know lol. . Cheers, Jake. Ah my mistake sorry. Use as many of the sensors you got with it and cut the plugs you need with a bit left to join them. Most ecu's(aftermarket) require: coolant temp. Air inlet temp. Throttle position. Map sensor(7ke one will only be 1bar not enough) If you don't have them that's still fine as I'm using mainly Holden temp sensors(air and coolant) which are resonably cheap. Having never seen a twin charger setup in real life I'm not going to coment on plumbing them in cause I'm going to be wrong. I've thought about it years ago but put it in the too hard basket. Stu. Report
April 18, 201115 yr Author comment_518005 So I got sick of my inaccurate fuel gauge readings, so I purchased a Speco branded fuel gauge and universal sender unit. At first I thought "Piece of piss" I thought wrong... As some of you may know the fuel tank has 3 "holes"; 1 for the fuel filler neck, 1 for the fuel sender and 1 extra sealed hole. At first I attempted to use the unused hole. Failed. Only realised after refitting the tank. So a week later, today, I had another crack at it. I dodgied up the original sender and cut it out and off and turned the 2 units into one and fitted it to the original/centre hole on the fuel tank. However, it did not fit as well as planned and required some bending and what not of the float and fuel lines. I got it in finally, fitted the tank, turned the key, SUCCESS! Kinda... The gauge now read above "F", so I probably need to adjust it slightly for the tank size. It's in, it's working, relatively. I'm happy. Cheers, Jake. Report
April 20, 201115 yr Author comment_518381 personally i'd copy this guys idea. f@$king genius! Thanks for that piece of video/info! Cheers, Jake. Report
April 21, 201115 yr Author comment_518723 Ran out of fuel tonight... DEFINATELY need to readjust the sender unit lol. I must admit it's a first for me, can honestly say I had never run out of petrol EVER! Cheers, Jake. Report
April 21, 201115 yr comment_518731 I'm waiting for my day to come, I can honestly say I've never had a car with a dodgy fuel sender . :laff: Report
April 22, 201115 yr Author comment_518781 I'm waiting for my day to come, I can honestly say I've never had a car with a dodgy fuel sender . :laff: Tell me about it, the amount of times I drove my VT SS with 0 KM to go and made it to a servo lol. Report
April 22, 201115 yr comment_518834 Haha brings back memories!! Remember the same thing in my old au 5ltr 1tunna. Parked it on a hill jumped in and checked distance till empty 140 km till none left got 5km down the road and she's dead oopps. Sucks having to walk to a servo!!! Stu. Report
April 23, 201115 yr comment_518967 I ran out of fuel once on the Westgate Freeway outbound just after the Grieve Parade exit, pushed my AE82 to the Mobil servo on the Ring Road outbound. Got to the off-ramp for it & that's when the Vicroads guy shows up, offers to push & gets told to bugger off. I'd made it that far... :bash: >| :bash: Sorry for the off topic bit, loving the build by the way! :y: Report
April 23, 201115 yr Author comment_518987 I ran out of fuel once on the Westgate Freeway outbound just after the Grieve Parade exit, pushed my AE82 to the Mobil servo on the Ring Road outbound. Got to the off-ramp for it & that's when the Vicroads guy shows up, offers to push & gets told to bugger off. I'd made it that far... :bash: >| :bash: Sorry for the off topic bit, loving the build by the way! :y: Wow, f@$k that! I'd shit myself if I actually ran out of fuel ON the bridge itself :P All good man and thanks! :) Good to have some support. Cheers, Jake. Report
April 25, 201115 yr Author comment_519329 Hit 170,000KMS on friday, felt it was worth mentioning :P Report
April 25, 201115 yr comment_519337 I'm actualy pretty pumped to see a super turbo charged corolla that videa was that a waste gat controled by accel and deccel on a carbie ?????????? Report
April 25, 201115 yr Author comment_519344 I'm actualy pretty pumped to see a super turbo charged corolla that videa was that a waste gat controled by accel and deccel on a carbie ?????????? Nah, pretty sure it's controlled by boost. Not 100% certain though, I'm gonna message the guy who made it with some questions. Judging by him using a bike pump to make it open, I'd say it was from boost. Cheers, Jake. Report
