Jono.C Posted April 26, 2011 Author Report Share Posted April 26, 2011 The front's ready to go in when i find some struts. Then i can pull out the ke10 crossmember and drill accordingly. I'll be using the ke20 tie rods on the ke10 steering setup for ease of use. Decided to strip back one of the front guards today. Completely full of bog. Knocked about 1kg out and did it properly. Quote Link to comment Share on other sites More sharing options...
KE20rollabus Posted April 26, 2011 Report Share Posted April 26, 2011 you want ke20 struts? what you willing to pay? Quote Link to comment Share on other sites More sharing options...
Jono.C Posted April 26, 2011 Author Report Share Posted April 26, 2011 Nah i'm after t18's, i had ke20's but they're the wrong stud pattern/ strut tube dia and the brakes are a bit small for what i'm after. But cheers anyway Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted April 30, 2011 Report Share Posted April 30, 2011 C'mon Jono. Get this little 10 done so you can pound Tas roads with some old school JDM 1 Quote Link to comment Share on other sites More sharing options...
Jono.C Posted April 30, 2011 Author Report Share Posted April 30, 2011 Hopefully in the next.. erhm, 12 months? :P Should be depending on the weather (and hungoverness :P ) be picking up my 3tc for this tomorrow. On a side note, i'm on rust repair duty today. :) Quote Link to comment Share on other sites More sharing options...
Jono.C Posted April 30, 2011 Author Report Share Posted April 30, 2011 (edited) Fitment Pic. 55mm Flares. 13x8.5 Steelies, 4.5" Dish, Will be wearing 175/60 :yes: Edited April 30, 2011 by Jono.C Quote Link to comment Share on other sites More sharing options...
Jono.C Posted May 9, 2011 Author Report Share Posted May 9, 2011 So, plans have changed. I picked up my 3tc for this and the weight of it is far too much for the car, it wouldn't handle, and it's too big. ha So, 4age is the way. Most likely 20v at this stage. Also this will now be brought to as overrated as possible for rego then all work done. Still got to find a ke70 crossmember and rack in tassie if anyone has one Cheers Quote Link to comment Share on other sites More sharing options...
Jono.C Posted May 11, 2011 Author Report Share Posted May 11, 2011 Got bored online (bad idea) and spent a heap of money. Ended up with a nardi wheel, bullet mirrors, dildo shifter and numerous other things. Also bought a pair of widened steelies for it today. :D Quote Link to comment Share on other sites More sharing options...
Jordain Posted May 11, 2011 Report Share Posted May 11, 2011 Good to hear! Get some more pictures. I'm going the same way.. 4AGE. I want to 20v silver/black top it but can't be bothered.. 7age 16v is enough Quote Link to comment Share on other sites More sharing options...
Jono.C Posted May 11, 2011 Author Report Share Posted May 11, 2011 7age would be cool, but the cost of it alone is enough to put me off. I was thinking of a 20v blacktop but i got offered a cheap 4age in need of cleaning up so that might cop some boost. Quote Link to comment Share on other sites More sharing options...
Jordain Posted May 11, 2011 Report Share Posted May 11, 2011 luckly i got a complete 4age 16v.. just ran dry on oil and had a bad clunk so motor came out. I got a friend who had an ae93 which got written off so I'm going to buy it off him for $100! Has a 7afe in it. I would like a blacktop.. there just so expensive and abit more work to get into the KE10 although still easily done Quote Link to comment Share on other sites More sharing options...
snotyellowke55 Posted May 23, 2011 Report Share Posted May 23, 2011 Man those rims are going to be PH-at as! Love it. I just bought some 13x7 mk2 spitfires for my '55 and they sit out from the stock guards, but yours stick out from flaries, I love it! :y: Can't wait to see this little beast on the road :wink: Quote Link to comment Share on other sites More sharing options...
Jono.C Posted May 23, 2011 Author Report Share Posted May 23, 2011 (edited) Haha cheers, i'm not running those wheels anymore, i got wider ones :P haha But the ones i had on the back where massive negative and had a spacer welded on. So the new ones will fit a lot better and i'll be able to run a ta22 diff. As the 8.5's were 4x110 Edited May 23, 2011 by Jono.C Quote Link to comment Share on other sites More sharing options...
snotyellowke55 Posted May 26, 2011 Report Share Posted May 26, 2011 Haha cheers, i'm not running those wheels anymore, i got wider ones :P haha Hahaha, man you're nuts, and I love it. Keen to see this baby evolve. I'm stressing about the potential of defect running my 13x7s, but it's a daily driven car I rely on to get me to and from Uni/Work. I actually think if I lower it, it'll attract less attention (massive guard clearance right now) - go figure. What setup do you plan to use for the front suspension? Quote Link to comment Share on other sites More sharing options...
Jono.C Posted May 26, 2011 Author Report Share Posted May 26, 2011 Tassie cops are pretty good i've found, unless you drive like an idiot you should be right. Well at the moment i'm not too sure on front ends.. I've got a ke20 front end i modded to fit but i'm not a fan of steering box, and i'm getting a ke70 crossmember to shorten up and see how it fits. Depending on how it goes i might have to mount rack and pinion to the ke20 crossmember, But i'd prefer not to as the geometry may be way off.. Apart from that, Most likely T18 lower control arms, Coilovered T18 struts with ae86 p/s knuckles for more lock, and less turns lock to lock, ajps lock spacer and ae86 jdm brake calipers. The ke10 steering column doesnt suit to how i drive so i might fit a ra65 steering column with the angle adjust. Apart from that ke20 swaybar/ castor rod frame, with a 22mm swaybar and adjustable castor rods. Thinking some otomoto adjustable strut top blanks might be the go and just drill them to suit. Main thing i'm working on at the moment is the body, 50~ hours spent on one front guard.. :( The worst i can see is around the windscreen and the gutters on the room which have split away from the car in places. Looking to be putting some serious time into this over tafe holidays. :happy: Cheers - Jono Quote Link to comment Share on other sites More sharing options...
