ok guys well i now have an early model ke20 and its a little bit different to the late model I'm used to.
basically the heater core appears to be just in front of the gearstick with no console over it or anything and the heater hoses and taps are just under the glove box?
is this normal i put a picture up to refer to! dunno if I'm missing a console or its just normal or what but any help is awesome cheers guys!
alright man not really sure how to do it all never realy worked with heaters or anything much maybe when I get it going I'll head to yours and have a look!
its easy as you will need the whole heater box setup and tap.
it will be a straight change over job
That looks pretty damn effective and I suspect puts out good heat
If I was you, I would wait till after winter to swap the new one in!
