August 9, 201115 yr Author comment_545616 http://www.youtube.com/watch?v=0hDuUvIG2so&feature=mfu_in_order&list=UL Edited August 9, 201115 yr by mitch-12 Report
August 10, 201115 yr comment_545758 still not tuned yet? very cool otherwise, also, did you check your oil cap after that big rev :P Report
August 11, 201115 yr Author comment_545839 tuning it this weekend haha the limiter is 6200 i just bounced it on that for a bit Report
August 11, 201115 yr comment_545866 Dear god...good to see it running but atm it sounds like a cross between a drop-saw & a whipper snipper! :o *Waiting for weekend * :lol: Report
August 11, 201115 yr comment_545870 Whats wrong with this picture...... Does a 3 year old do your machining? Report
August 11, 201115 yr comment_545874 I think it sounds awesome! Hendo would be proud of your side pipe :P Cheers, Jake. Report
August 11, 201115 yr comment_545954 Whats wrong with this picture...... Does a 3 year old do your machining? ROFLLLLL :lol: durrrr hiyah maa derp derp derp Report
August 11, 201115 yr Author comment_546009 i like the sound :) I'm tuning it tommorow now Whats wrong with this picture...... Does a 3 year old do your machining? are you talking about the surface not being done haha I'm using the old clutch so we left it and it was free so it doesnt matter Report
August 11, 201115 yr comment_546020 Racing on a budget, if its free and it works its within budget :y: Edited August 11, 201115 yr by Rob 5000 Report
August 12, 201115 yr Author comment_546190 been to the dyno made 102.4hp atw with 9psi at 5500rpm with BP Ultimate sheet with boost and lambda Report
August 13, 201115 yr comment_546271 Cracked the triple digit mark first time out, nice! :y: Keen to see E85 + more boost figures. :) As well as how long the standard clutch lasts. :lol: Report
August 13, 201115 yr Author comment_546284 also you will notice on lambda graph its tuned rich to be safe Report
August 14, 201115 yr comment_546532 If your running a KE70 box with I assume you would be, grab a 200mm clutch off of a KM20/36 hiace, 200mm clutch just fits in a Ksev bellhousing. Not a KE3x/55 one tho. Report
