JJT036 Posted April 25, 2012 Report Share Posted April 25, 2012 Your work is really awesome mate. Keep it up. Can't wait to see a vid of it running and/or driving. :y: Josh :cool: Quote Link to comment Share on other sites More sharing options...
haveaparty Posted April 26, 2012 Author Report Share Posted April 26, 2012 Cheers man. Not doin to bad considering I've never done anything like this before. Having done panel beating for 4 and a half years helps tho lol. And will defs be making a video on completion. Quote Link to comment Share on other sites More sharing options...
haveaparty Posted June 19, 2012 Author Report Share Posted June 19, 2012 Painted the front end. Not bad for a can job Quote Link to comment Share on other sites More sharing options...
haveaparty Posted June 19, 2012 Author Report Share Posted June 19, 2012 Also just realized I didn't show off my jdmness Quote Link to comment Share on other sites More sharing options...
Kustom Posted June 19, 2012 Report Share Posted June 19, 2012 Love it man! Good work, keep it up ! Quote Link to comment Share on other sites More sharing options...
glenpos Posted June 19, 2012 Report Share Posted June 19, 2012 looks good mate, spoto a hr wagon :D Quote Link to comment Share on other sites More sharing options...
haveaparty Posted July 1, 2012 Author Report Share Posted July 1, 2012 Got some motivation this arvo so started the final fit up Clutch and brake stuff in. Winning moment. Ae71 clutch line fitted perfectly onto f20c clutch slave Underneath Quote Link to comment Share on other sites More sharing options...
19914afc Posted July 1, 2012 Report Share Posted July 1, 2012 How have you ended up doing the engine mounts on crossmember? Thats what mine look like pretty much. (the engine and rubber mounts I mean) Quote Link to comment Share on other sites More sharing options...
haveaparty Posted July 2, 2012 Author Report Share Posted July 2, 2012 Look back a page. Pretty sure I put photos up on how I done it. Just some tube steel cut in half and the s2000 locating plates flipped upside down and welded all up. Quote Link to comment Share on other sites More sharing options...
haveaparty Posted July 15, 2012 Author Report Share Posted July 15, 2012 I started mocking up the dash loom to run power to ecu and dash. Could get past the immobilizer. So I thought I would try plug in some other Honda looms I had to see what would happen. So started with this That was a fail so did some research and turns out the immobilizer can be removed from the ecu Won't say what chip I removed but ecu looks like this now Then at about 10 Friday night I stared stripping the loom back to just the bare essentials At about 3am I ended up with this Wired everything in today. Couldn't get the dash to work and figured I ʞ©$ɟed something. So studied the pinouts one more time to be sure and found I missed a ignition 12v wire. Then this happened, followed by a little bit of froth Quote Link to comment Share on other sites More sharing options...
radrollaz Posted July 15, 2012 Report Share Posted July 15, 2012 Looks good mate, i like your work. I'm doing similar conversion atm into KE30. Just got motor mounted over the weekend,just need to make the gearbox mount now. Quote Link to comment Share on other sites More sharing options...
rian Posted July 15, 2012 Report Share Posted July 15, 2012 ZOMG! Quote Link to comment Share on other sites More sharing options...
It's_AUDM_Yo Posted July 16, 2012 Report Share Posted July 16, 2012 S2K dash cluster are off the chains! Quote Link to comment Share on other sites More sharing options...
dbr11k Posted July 16, 2012 Report Share Posted July 16, 2012 that cluster is so sexy! i will be wiring in a haltech dash in a few weeks, wish it looked like this but! Quote Link to comment Share on other sites More sharing options...
haveaparty Posted July 23, 2012 Author Report Share Posted July 23, 2012 Interior completed again. Just need to get some flooring eventually. And mount the cluster properly. Little bit of cutting will be involved here. Along with some zip ties to hold it in. I like this photo Quote Link to comment Share on other sites More sharing options...
