V-Tec Yo
  • Replies 113
  • Views 157.5k
  • You can plastic weld with superglue and baking soda.
  • Finally some progress on this. Only small but still pprogress. Engine bay was painted in 2pac white. Look alot neater then the can job I did at first.   Cleaned up the master cylinders. Bit of blac
Dash mounted in. Just got to make legit brackets
looks good, keep those pics coming.
speedo???? digtal speedo?????
if so = :y: :y: :y: :yes:
What an I plastic welding tho lol. And yes digital speedo. Look Back a page and u will see it
yep............. i like to see when it roars........... brum bruuuuuum............ :wootjump:
Interior looks super neat! Dash install is pretty cool as well
How strong are those mounts on the Crossmember? They just look a little on fragile side?
Said you needed some proper brackets to hold the dash cluster in. Thought you could just plastic weld them on.
Interior is m int condition. Except for a tear in the drivers seat and in the roof lining. No cracks in the dash either. We will find out soon if the mounts will hold up. I think they will be fine. But if not I will redo the cross member.
I got some stainless steel to make brackets out of and also to fill in the gap between the cluster and dash surround. Mate got it from his work as scrap bit might need to find some thinner stuff to work with. Is fairly heavy for only a few small peices
dash looks so sick mate, good work !!
So after a couple weeks of ripping my hair out wondering y this wouldn't start, I got it running yesterday. Turned out I had a ʞ©$ɟed knock sensor. So car starts now.
Awesome news!
Any vids? ;)
