September 4, 201115 yr comment_551263 hay guys just slamed my twin side drafts on friday. its running super duper rich as its jetted for a 2tg my step dad reckons that i should get a real good igntion system to burn all the fuel plus extractors whats your opinion for better ignitions systems ect :wink: cheers matt. p.s can you put a t series twin cam head on a pushrod t series block any possibility with that Edited September 9, 201115 yr by t18drifts Report
September 4, 201115 yr comment_551315 No matter how much spark you give it, if there is insufficient oxygen to complete the combustion you will have unburnt fuel exiting the exhaust. No witchcraft going on here, just simple chemistry. Likewise with extractors, you're still going to have the same/similar ratio of fuel/air just perhaps more of it. Address the issue directly ;) Report
September 5, 201115 yr comment_551459 There are all soughts of possible issues with the twin solex setup you will run into. You need equal fuel distribution and pressure. Ditch the inline fuel delivery and make up a T section delivery. Get a fuel prssure regulator. They run around 3 psi. Not a great deal of people know anything about sidedraft solex carbs. Parts/jet kits are harder to source than dellorto parts. Bits get loose over time (venturies). You should run tube headers with or without the twin carbs. At the end of the day don't do what I did and try and make it work yourself. As stated 'witchcraft' no worky worky. Bolt them on and get it to the tune shop... I gave up on my Type T solex setup because I realise now that I went completely the wrong way about it. Edited September 5, 201115 yr by GJM85 Report
September 5, 201115 yr Author comment_551489 aww yeah true my major issue at the moment is my throttle is getting stuck/sticky wierd witch craft no worky worky accelerate and it slowly come bak down to about 2grand start it up after manual pushing the throttle on the carbs down itl will idle niclely at 1grand then slowley rises to 2 grand on its own :hmm: Report
September 5, 201115 yr comment_551523 Put another/ bigger return spring on your lingkages/ butterfly shaft. If it hasn't been dyno'd, they'll be about as much use as a bicycle to a fish. Dyno will solve all. Or at least tell you what you have to do. Report
September 6, 201115 yr comment_551589 The solex carbs are alright but like said above harder to find parts for and not the best carb available, I had them on my car jetted for a slightly bored and worked 2TG and they where OK on my 3T just gave them a tune by ear with a piece of hose and it ran alright but kept getting an air leak because of the manifold I had on there so just f@$ked them off and put a simple single 38/38 weber on. Report
September 6, 201115 yr Author comment_551772 yeah i have that many springs on there is isnt funny but its still not holding it completly shut but its bere tonight after i f@$ked around with it more also were should i go for a better coil I'm not to sure :glare: Report
September 6, 201115 yr comment_551785 GT40 are alright, otherwise have a look on the us sites for race upgrade or whatever they have. Report
September 7, 201115 yr comment_551830 www.wolfcreekracing.com. Are mikuni distributor and are happy to post to Aus. I've bought rebuild kits from them in the past and hopefully some CV shafts for the r200 diff conversion in dads datto. Stu. Report
September 7, 201115 yr comment_551958 If you have had the float chambers apart, just check to make sure you have the choke disc's lined up properly before you put the tops back on. Common problem is that that get lined up wrong and the chokes are on all the time. Report
September 7, 201115 yr comment_551994 If they're not closing properly make sure everything is completely flat. If you have twin carbs then the spindles should be near to exactly in line and not binding. If they aren't then they might not shut properly. To do this make sure everything makes lines up properly. Both the bottom and top faces should be parallel to the manifold and in line vertically. Weird slow rev down might also be an air leak or mixtures. Report
September 7, 201115 yr Author comment_552041 If you have had the float chambers apart, just check to make sure you have the choke disc's lined up properly before you put the tops back on. Common problem is that that get lined up wrong and the chokes are on all the time. interesting hmm would that cause the butterfly shafts/throttle peice on the carb to grab and be a a little stiff ................................................ ok just tried somthing and it seem the wd40 lossend the her up a bit and isnt as bad but i noticed somthing else i didnt notice before ( i have no idea why i didnt ) but I'm only running on cyclinder 1 and 2 proberly why i am running rich we swapped leads over with the ones on 1 and 2 they still worked with 3 and 4s leads getting a pretty weak spark out of the plugs from 3 and 4 4 is not even firing same with 3 ocasionaly one of the 2 will start up :hmm: Report
September 7, 201115 yr Author comment_552043 If they're not closing properly make sure everything is completely flat. If you have twin carbs then the spindles should be near to exactly in line and not binding. If they aren't then they might not shut properly. To do this make sure everything makes lines up properly. Both the bottom and top faces should be parallel to the manifold and in line vertically. Weird slow rev down might also be an air leak or mixtures. yeah one carb is higher then the over well the poll that runs threw on each carb were the throttle and butterflys are attatched are at noticible distence verticly from each over :hmm: Report
September 8, 201115 yr Author comment_552231 ok today i got new plugs gt 40 coil dissy cap and rotor i can still pull the lead of number 4 and makes no difference have changed the leads bettwen the working ones and they all work so it beats me :blinks::blinks: Report
