May 1, 201313 yr Author comment_654906 That technology has been around for a while, but I had no idea it would work on such a large scale. They must be getting some serious lift out of those hydrofoils. Report
May 1, 201313 yr comment_654907 I knew the tech existed but yeah, those things are huge! I think I'll be interested in watching it this time around. Seems they have tightened the rules so there will be only this one class of boat . Plus NZ is in the challenger series ;) Report
May 10, 201313 yr comment_655712 Wanna get mad? This guy spent 250K on his R35 and this was the result. http://www.gtrlife.com/forums/topic/85083-forged-performance-the-truth/ Report
May 10, 201313 yr comment_655718 Wanna get mad? This guy spent 250K on his R35 and this was the result. http://www.gtrlife.c...ance-the-truth/ it happens and will continue unfortunately Report
May 10, 201313 yr Author comment_655724 What was that guy thinking spending $250000 on modifying his car?!! Report
May 12, 201313 yr comment_655838 Hey, first post here (Hi!) I've got a TA22, and usually frequent toymods.com but the forum seems to be down? Does anyone know what's happening there? Also are celica owners welcome here? It starts with a C and its made by Toyota! :P P.s. is the toyman75 on here? I was in the process of buying an engine off him Edited May 12, 201313 yr by Ashh Report
May 12, 201313 yr Author comment_655845 TA22's are awesome, post a pic! Edited May 12, 201313 yr by rian Report
May 12, 201313 yr comment_655848 Haha I agree! I don't have many good pictures of it but here's one from a while ago: The paint is actually a vinyl wrap that the previous owner did. I've just been trying to keep her running and so far have done the clutch, head gasket, radiator and wheel bearings. Soon to replace the struts with some xt130's and hilux brakes that I've got just havent had time to fit. And then there are only a thousand other things to fix... Haha Does anyone know why toymods is down? Report
May 12, 201313 yr comment_655894 Stick this in your Rolla. http://www.vincelewis.net/bigengine.html Report
June 19, 201313 yr Author comment_659386 Who has put in stiffer front or rear swaybar in a KE70? I've just ordered a Whiteline 18mm rear swaybar which I'm picking up tomorrow but I probably won't put it in the car until after I've driven it with the factory swaybar so I can make a comparison. I've been doing a fair bit of research, but I'm yet to do any calculations on whether or not I'm going to gain or lose traction from this "upgrade" (not sure if I could be bothered to either, or how accurate the calculations would be). Who has swapped to a bigger swaybar at either end of a KE and what change in handling did you notice afterwards? Also what size swaybar and what spring rate are you running. I've been thinking that an 18mm rear swaybar is going to decrease traction in the rear end by a smidge, which should make the car more fun to drive at the track (which is all I'm looking for really). So if anyone has fiddled with swaybars please post up your experiences, whether or not you gained traction, if the car became easier to corner etc. I'd be particaularly interested in hearing from people who have done front swaybar upgrades, I've heard of people removing front swaybars but haven't really heard much about people going for bigger front swaybars. Report
June 19, 201313 yr comment_659400 There is plenty of talk of swaybars in silvia land and I played around with them on my KE70 The general consensus is its more the difference in size of the swaybars than the actually size of the swaybars. Large bias to the rear is "oversteer ier" Large bias to the front is "understeer ier" My rolla actually felt good with the front swaybar disconnected I had 8kg springs, turn in felt way better had a bit more oversteer also. Factory swaybars on KE70s are like paperclips so I reckon you will get a similar result. A lot of people have said with really large front swaybars/ no rears. Is that once the rear swings out that its very hard to get it back under control but does feel like it has more grip/pushes in corners. Tried it disconnecting them on my KE70 and it just felt super unresponsive and semi uncontrollable. Some dudes even run no swaybars at all but they run like 14kgs in a s13 But like all suspension its really a case by case type deal and what you like the feel of. Edited June 19, 201313 yr by It's_AUDM_Yo Report
June 23, 201313 yr comment_659715 Last night I got contacted by a private forensic investigator working on the Daniel Morcombe case. I can confirm that they are looking for a light/baby blue KE70 sedan. Report
June 23, 201313 yr comment_659717 Last night I got contacted by a private forensic investigator working on the Daniel Morcombe case. I can confirm that they are looking for a light/baby blue KE70 sedan. Really because your like an admin on here? Report
