October 30, 201115 yr comment_563412 Gday guys. I am a short while away from putting my 150A tighe ground cam into my 4k, hopefully getting my dellorto or the 32/36 tuned to suit. Flywheel has been lightened alot, and compression will be raised a little, after i work out the dynamic CR. Anyway, is it possible for people to put up their 'before and after cam' experiences, and i would really love to see a dyno, or a running/driving video for comparance. I have searched and searched, but can not find a before and after. The 150A is a pretty cranky wild cam, with 292* advertised duration, and .474" lift :happy: (which i have double springs to suit) blah blah. I'd love to hear your experiences guys, and ideally id love to see a dyno comparison or running/driving vids, and what cam you have used. Thanks guys, Luke. Edited October 30, 201115 yr by ae824ate Report
October 30, 201115 yr comment_563555 Hey mate, I reckon there's probably an existing thread with the same discussion, it's floating around somewhere, I'll see if I can find it. in the meantime, big cams are wicked, when setup right with carbs and extractors and tuned the kick in the guts from a cam is amazing, and when you're pulling 7000rpm the sound furious. Report
October 31, 201115 yr Author comment_563651 Cheers philbey, i had a bit of a look but couldnt find anything. A link would be great. Anyone else with fist hand experience? This is my first K engine, I'm a K virgin :blush: Report
October 31, 201115 yr comment_563716 well i had a 3k that was running 31hp at the wheels :dance: swapped it out for a 4k we rebuilt cammed, lightened flywheel, increased comp, carb etc. havnt had it dyno'd but id say its making at least twice the power... can't find the cam specs though but it was like 270 duration 4.1 lift. revs to like 6k and blows excels off the line :laff: Report
October 31, 201115 yr comment_563740 Here is a vid of my cammed 5k in action. From memory it was a Wade 169. It was running 3k-b carbies. The test wasnt the best to let it have its head, in others it would have the shift light lit up all the way. This was set at 7500rpm. My link Again no dyno sheet but going from a std 3k to the cammed 5k (still on a single carby then) was worth a couple of seconds a lap on the autocross circuit. My link 2 The white KE20 in the above video had a reground cam of unknown specs. An ex who we built it for asked for a power band from 4000 rm up. This is what she got. It would come in STRONG at 3600. Enough that it would easily turn you around if you were cornering on dirt and hit 3600rpm. Report
November 1, 201115 yr comment_563834 the tighe 113 works pretty well for my setup...........................beware ive had a dud grind from tighe in the past, couldnt get it dialled in.......... Report
November 1, 201115 yr Author comment_563842 Thanks guys. The 150A is a pretty cranky grind, I'm very curious to see how it will run with the dellorto, and upped compression. It already has a very light flywheel, extractors etc, i just hope all these ingredients bake a sweet, reliable brappin cake :blush: Edited November 1, 201115 yr by ae824ate Report
November 12, 201115 yr Author comment_565805 Here is the results of the cam install, after running it in. The double springs have been installed now, and am looking forward to a good tune, and a road test. Brap brap to all, and to all a good night. http://www.facebook.com/l.php?u=http%3A%2F%2Fwww.youtube.com%2Fuser%2Fozgrappla%3Ffeature%3Dmhsn&h=5AQEm8kW1 Report
November 12, 201115 yr comment_565819 I'm keen to see what this cam is like once you have the car tuned i was considering 150A for my 4k build but after speaking to the guys at tighe i will be going with something broader rpm range Report
November 13, 201115 yr Author comment_565936 Cam is in, been run in, and double springs are in. Currently breathing through the stock carby. And um, I'm not sure how to describe it. Almost nothing down low, even taking off on level ground. But god it loves to rev!! Gain power at about 3K, and at 3.5-4K it starts pulling like a 14 year old until 6-7K. The stock carby struggles after 6000ish, and I'm sure the weber or dellorto will feed it enough fuel in the higher rpm. Ideally i should have had the head shaved for compression while doing this, but it was a bit of a rush. I have before and after videos, and will possibly put them up on youtube soon. I don't think i will stick with the 150A for long, it just wont be practical for city driving, its an animal with this cam. It has a cranky lumpy idle (not in the video, but sounds like a rotary) Fkn brap brap!!!!. I do not recommend a grind like this for street/daily use. Its suited to rally/race. I will put a link up to a video shortly. Cheers, Luke. Edited November 13, 201115 yr by ae824ate Report
November 13, 201115 yr Author comment_565960 Edit, never mind. Edited November 13, 201115 yr by ae824ate Report
November 13, 201115 yr comment_565965 i have a 240 duration @ 50 thou cam in my 4k. i felt a BIG flat spot till 3 grand then the cam kicked in, at that time i was running 8 degrees of timing. now running 22+ and no flat spot and pulls like a school boy. i think its the same as a tighe 150A. is it to big to be in a daily? f@$k no! cam kicks in at 2750. rev it till 4 and change gears and youll still be in your cam range in the next gear. 2nd gear is 95kph, 3rd is 120ish 4th is off the speedo :P go hard or go home Report
November 13, 201115 yr comment_565967 i have a 240 duration @ 50 thou cam in my 4k. i felt a BIG flat spot till 3 grand then the cam kicked in, at that time i was running 8 degrees of timing. now running 22+ and no flat spot and pulls like a school boy. i think its the same as a tighe 150A. is it to big to be in a daily? f@$k no! cam kicks in at 2750. rev it till 4 and change gears and youll still be in your cam range in the next gear. 2nd gear is 95kph, 3rd is 120ish 4th is off the speedo :P go hard or go home I can verify this :) Report
November 13, 201115 yr Author comment_565984 Thanks Evan. Edited November 13, 201115 yr by ae824ate Report
