hello
before i get flamed ive searched the forums and google can't find anything that helps me.
all i want to know is what model sierra shocks you guys are running?
year, soft top or hardtop? etc.. the more info the better. I'm trying
to order a pair in but autobarn keep ringing me saying they don't know
which ones i want. also gabriel or munroe? they quoted me 100 each, is
that decent?
thanks in advance ^__^
Holden Commodore VK-VS Sedan rear shocks > Suzuki Sierra shocks.
Most people that I know of use commodore rear shocks and they were about half the price of the Sierra shocks last time I checked at Supercheap Auto. Also the Sierra shocks are too short to allow any decent droop according to about every thread on that topic that I have read on the internet. I'd get the VK-VS commodore rear shocks over the Sierra shocks, also if you want good ones get Koni, Bilstein, KYB AGX etc.
I had Sierras, they were win. Get whatever is cheapest. Gabriel should be fine.
From memory it's 1986-1992 Front shocks, can get them on eBay for around $140pair.
cheers for the replies. the car isnt for street use i want it stiff
and cheap. i told them the year but apparently theres lots of
different models so they keep ringing me back saying which ones
do i want....
If you must get the sierras then get front shocks from a sierra/jimny. Most list Jimny not Sierra these days, however, you will have a low and unsafe car with next to no suspension travel and no droop, which just means when you're at the ragged edge you will skip off and lose contact with the road, which will mean you can't control the car and end up crashing. Popping the inside wheel into the air is a sign of a lack of droop, not a fast car. There is no substitute for quality dampers, and correctly wound springs, until you actually bother to get something decent sorted, you will never know.
Not for street use!!!!
what little redspirit said!^^
a member on here had a ksev with choppies and sierra shocks. it was dangerous! no droop. very twitchy and just wants to oversteer. (this was at 100kph :| )
rear end was rock solid. save your self $140 and just install metal tubing as shocks!
do NOT recommend them. go commodore wagon rear shocks
  • Upvote 1
is this for ke70? he never said..
For wagons they are ok because wagons come with shorter one to start with. Got mine from pedders they said they would be fine and I like them but I wouldnt for sedans...
oversteer is the plan :) i got xf kingys from upullit gonna
go halfies. just need get the front as stiff now! anyone
know cheap way to get front as hard? i got xf spring for the
front to diameter was close but gotta fit them tomorrow.
its for ke70 sedan
like i said guys, this car is by no means for the road, and
I'm not gonna lie i considered welding two bars in haha.
Edited by Dowsett
ive driven an 86 with VERY low springs and sierra shocks
absolute GARBAGE. not even for a drifto mobile....rubbish.
for springs around the 4-6kg range, on the cheap, i recommend the wagon commondore shocks (KYB part number 343113).
very good shock and a nice length, keeps the springs captive but allows for a good amount of suspension droop.
also check this out on ebay atm:
http://www.ebay.com.au/itm/used-Toyota-Corolla-KE70-AE86-Sprinter-Koni-Yellow-suspension-Struts-Brakes-/180785015990?pt=AU_Car_Parts_Accessories&hash=item2a17a06cb6
those konis are the good stuff, check the lengths etc, but they might be a bargain at that price, would need a rebuild though.
do i have to make a account to see the spreadsheet pyrohamish?
sounds perfect, stiff as. can't handle the body roll anymore
and the car is way to aggressive when i try to link corners.
that set up looks cheap and its close too, but can't wait for
rebuild :)
i just need to know the part number for gabriel of the exact
shock i need would make it easy!
thanks heaaps
i use kyb front sierra shocks on the back of my ke35, they are shorter stroke, my car lowered 2 inches hasnt given me any major issues.. very stiff, i agree not enough droop thou,can be issue on steep driveways if your on a angle...inner wheel of the ground lol
