Ke70 Exhaust Under Or Over Diff
Hey
I'm in the process of doin the exhaust on my v6 project, I'm running twin individual 2 1/4 system and i just got to up to fabricatin the section that passes the diff, i would like to run it over the diff, but space is limited so I'm tossing up whether to run it under the diff,
Wats everyones opinion, does anyone run the exhaust under the diff,wouls the diff hit the exhaust over big bumps or the exhaust hit the ground over bumps
Thanks
You need decently short stroke rear shocks to pull it off without the exhaust hitting diff, and theres no problem with the ground as long as you don't drop the exhaust down any lower then it is up front.
Do the hard yards now and go over diff, I think you will thank yourself later. Even if the car is going to be under legal height that system should be able to fit between the diff and body, it will just be a tight fit
over diff to be safe.
Ran the exhaust under the diff on my KE20 club car. Didnt have any issues with the exhaust hitting the diff or the ground. May have had a couple of scrape marks on the exhaust but nothing major. This was with lowered rear springs.
My daily driver HD holden runs a twin system under the diff and i havent had a problem,
the car sits about 105mm off the ground. i reckon do what fits
I'm leanin towards goin under the diff just for the ease factor when fabricating but,  i wanna keep the stock factor and hide as much as i can, later I'm gonna get under the car and sus out how hard it will be to run it over
  • 2 months later...
hey, how did you go with under the diff system? My exhaust hits on my ke70 which is lowered.
hey bud, it went well, looks really good, the only problem i have is u can only jack the rear up from the diff as if u jack from thw body the diff hits the exhaust
I done the same thing under the diff exhaust worked out really well
I have commo wagon sports/short stroke shocks under mine and have no problems with hitting anymore
Do any of you guys have photos of the under diff exhaust system?
This is the only photo I have of mine, I'm not particularly fond of under the diff exhausts. I haven't measured it but I'm pretty sure the exhaust is illegally low, I'd rather have an over the diff exhaust and have the car being legal.
Edited by rian
