Ke25 Diff To 114.3 Pcd & Disk Brakes
Carts
Can someone help me I have a ke25 and need 114.3 PCD with disk brakes and about 4.11 to 1 ratio or 3.89 and max width of about 1300mm setup for 100kw engine. What diff can i use. R31 bw78 can only be shorten to about 1370mm need to do about 1300mm to fit deep dish wheels that look great old school. R31 diff to get 1300mm need to shorten axles gets to mutch cost. can someone please help me. Carts
:huh:
Theres only one diff that somewhat bolts in but it has its own issues,
its the 8 bolt d series out the ta22, and I think a t series 10 bolt centre can be fitted.
The leaf spring pads are 20mm out or so and so can be forced on but wear out bushes
rapidly or do it right and relocate spring pads inwards which is a bit of work.
http://www.toymods.org.au/forums/tech-conversions/65900-ta22-gearbox-diff-problem.html
http://www.toycrazy.net/index1.html
You pretty much have to shorten a diff, try r31, t series, f series converted to disc or
the other less common alternatives last I remember were are g series, alfa 105, volvo dana,
9 inch ford, ford escort mkI/II, mazda rx3/4/5/7 etc
You can't legally have a diff under factory length, I know it would be ideal
to have 1300mm for wheels but you can't get it engineered, gotta be 1320mm or more as shortening
the diff causes the track to decrease which affects stability, I know it can be altered with
wheel offset but the factory wheels still have to work if ever used, hence the reason its not allowed.
Edited by styler
Thanks for the info but i still hoping for a diff with the magic 1320 mm disk to disk. To do the r31 diff it will end up to wide as the wheels only 20mm - offset. I must use these wheels because they look great and where free.
You use two short axles in both sides but it still ends up at 1410mm total and offset diff center. So maybe shorten shorten one side more will get the center closer to where should be and give me 1320mm Thanks that will work better and should cost me about $750
  • 5 months later...
I saw these on yahoo the other day. A bit ghetto, but may be ok if you are a good welder.........
The translation to Japlish says, "Was removed from the 2-door Corolla KE10 late.
KP61スターレット用のRシャフトを改造してPCDを110→114,3に変更されています。
Has been changed to 110 → 114,3 PCD make modifications to the R shaft for KP61 Starlet"
I saw at just toyota 5 odd years ago a RT104 with a t series diff in it on leaf springs. it was perfect and would fit a ke25. I'm annoyed I didnt buy it as the car got scrapped when just toyota changed focus. I have a similar problem. I'm think of LSD options for my 71 KE25. not sure what to do. I am only staying old school K motor in NA form. but would like LSD.
Any thoughts?
one other option would be putting flares on to cover the tyres then you can have the slightly wider diff and still have your deep dish wheels covered
